Sponsored by: Innova
Single cab sound issues
Old May 28, 2008 | 02:22 AM
nosetackle63's Avatar
nosetackle63
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>Hey, so im having troubles finding places to put sound equiptment in my 1973 F250 Highboy. Its a single cab, and the only place i could imagine putting a subwoofer would be in the glove box (the inside of the glove box is ripped out). Then comes amps and speaker placement. Any help??
</TD></TR></TBODY></TABLE>
Old May 28, 2008 | 01:35 PM
Blue86f150's Avatar
Blue86f150
you could do what i did, and everyone else, and put everything behind the seat.
Old May 28, 2008 | 03:05 PM
Old Ford Blue's Avatar
Old Ford Blue
He's got a gas tank back there, so I guess not everybody did what you did. Highboys(and several of the pre 79 trucks) had a 19.5 gallon gas tank behind the seat and it takes up ALL of the room back there.
I to am up the same tree.........
Gabe
Old May 28, 2008 | 04:27 PM
Blue86f150's Avatar
Blue86f150
Gotcha, my bad. I just dont know my Highboys. My first suggestion would be to convert it to bucket seats instead of a bench(again not sure what they come with), and build a box that would fit inbetween the buckets. If you wanted to get custom with it you turn it into a center counsol/subwoofer box. If you have a bench and want to keep it that way you could still do a center council/sub box or sub box and put it in the red square in the picture. Or if you wanted to go all out, make some custom door panels to house an 8" 10" shallow mount sub if you wanted.
Old May 28, 2008 | 05:43 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
The glove box idea is very intresting. But i dont think there would be enough space for a proper sub box... In my 69 I went with the box over the trans tunnel. I had 2 8"s and also 1 12" and both sounded ok.... Eventually it will get buckets and a pair of 12"s in a custom console...
Do you have an idea's for the glove box thing? I would like to hear how you would get that to work. Would be intresting.
Old May 28, 2008 | 08:50 PM
nosetackle63
My truck has a manual tranny, so putting anything on the trans tunnel wont work. The bucket seats are a good idea, but considering im only 16, money isnt very abundant for something like that. I suppose i could do a little at a time.
Old May 29, 2008 | 01:00 AM
nosetackle63
Could I cut a section from the middle of the seat and put in a sub box/console? Or would that be more trouble than it is worth?
Old May 29, 2008 | 09:40 AM
Blue86f150's Avatar
Blue86f150
I would have to say more trouble than worth it. I'm kind of in ur situation. I have a bench seat, but i am looking for bucket seats to put in it. I'm looking through craigs list, and auto junk yards by my house. You might want to think about doing that to.
Old May 29, 2008 | 08:12 PM
Old Ford Blue
After re-reading my post, I want to apologize as it sounded somewhat....shall we say snotty? Anywho sorry bout that.
I do like the idea of a console on the tranny hump......even with a bench.....hmmmm
Old May 29, 2008 | 08:43 PM
Truckin4life
Maybe a set of econoline seats... I got some on the cheap for my truck... To bad i didnt get a chance to install them...
As for cutting the seat it might be ale to be done... Maybe cut out part of the seat... Then make a box to slip down in there and cover part of the seat where you cut... i dont think it would be to spendy either... Maybe do that for temp until you get ready for some buckets...
Old May 29, 2008 | 09:02 PM
nosetackle63
Exactly, if I cut the seat it would strictly be temporary until i can afford buckets. Im thinking craigslist and ebay will be my best choich for creap parts, i dont really like the idea of spending $1200 for a new seat
Old May 29, 2008 | 11:52 PM
bgalaxy67's Avatar
bgalaxy67
What about this?
I'm going to assume that the pic in your sig is the truck in question.
You can use the room you have under the bed box to build yourself a ported pox and have just the port come through to the cab.
Old May 30, 2008 | 10:40 AM
BradyCouchman's Avatar
BradyCouchman
when i had my 2 door 69 i took the bench of of its sliders and built a square frame and mounted 2 dodge ram seats to it then built a box to hold 2 12s that pointed down that mounted to the square frame. the seats came from a swap meet, $50 the frame was bolted together and cost about $30 the box i made my self and cost $20 for the sheet of MDF, and the subs and amps i had, it was soooooooo loud. plus it was nice to have a center consel. and come to think of it i was only 17 at the time, had my dads help but was also low on funds.
Old May 30, 2008 | 08:22 PM
Truckin4life
I agree with b-galaxy if you dont mind cutting on the truck...
I did something VERY similar to what brady described. But i never got a chance to install it all...
Old May 30, 2008 | 10:32 PM
bgalaxy67's Avatar
bgalaxy67
You could even get one of those pre-fabbed Bandpass boxes from a local retait store and then pull the ports stick them so they are outside the box then drill out the small holes in the cab and slide the box with ports right in.
morrisjl2
General Diesel Discussion
Apr 30, 2009 03:00 PM
indebt
Nov 7, 2008 09:29 PM
Bowie
Nov 6, 2008 03:05 PM
scottbirdsall
May 15, 2008 10:47 AM
Grabber
Dec 12, 2006 03:21 PM
