tire size
Old May 25, 2008 | 01:17 PM
mkrog's Avatar
mkrog
tire size
The tranny in my truck is out of a 69 Montego,does any one remember what size tire was on the Montego.
Old May 25, 2008 | 02:36 PM
ghall's Avatar
ghall
just a guess...
F78-14 probably no more than a G or H
Old May 25, 2008 | 06:05 PM
imlowr2's Avatar
imlowr2
They were the same rims and tires as my dad's 69 Cougar. 6.95/75R/14. It was a steel wheel with a hubcap.
Old May 26, 2008 | 09:01 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Why do you ask? Hopefully, you aren't planning to use the same size on your truck are you? The original tire for the Montego is too small for a truck...
Old May 26, 2008 | 12:20 PM
jaye's Avatar
jaye
If you are attempting to match your tires/rims & tranny in order to get the speedometer' speed correct you can just change the plastic gear in the tranny; from a local Ford dealer should be less than $10 each.
Old May 27, 2008 | 01:55 AM
mkrog's Avatar
mkrog
No I'm not going to use that size tire on my truck.I need it for the speedo .I was just checking to see if the gear in my tranny would be close for the tires I'm goining to run.
Old May 27, 2008 | 06:03 AM
GreatNorthWoods
Your best bet is to put whatever sized tires you want on it and give it a test drive. Any tire with a larger diameter than the original Montego tire will slow the speedometer down. Figure out how much the speedometer is off. If it's slow you need a speedometer gear with fewer teeth (if it's too fast you need one with more teeth). Generally, each tooth is worth about a 5 MPH change. Be aware that there may not be a gear made which is right for your particular transmission/rear end ratio combination. I'm running a 2:26 rear gear and the best I can do is 6 MPH slow on the speedometer since I'm already using a gear with the smallest number of teeth available for my transmission.
67nukeford
Nebraska Chapter
Jan 28, 2014 05:05 PM
johnson2007
Nov 15, 2010 02:19 PM
montego69
Apr 12, 2010 09:57 AM
polarbear
General Automotive Discussion
15
Dec 7, 2005 12:54 PM
joelsutter
Sep 12, 2004 07:29 AM
