water pump gasket
Old May 25, 2008 | 08:14 AM
mike L's Avatar
mike L
water pump gasket
I didn't add gasket sealer before installing water pump. I just used the the gasket. Will it leak?
Old May 25, 2008 | 09:23 AM
Animalistic's Avatar
Animalistic
I just replaced my water pump about a month ago and I just used the gasket that came with it. No sealer. As long as the mounting surface is clean and you torque the bolts to spec, you should be fine.
Old May 25, 2008 | 11:23 AM
jonpfeifer's Avatar
jonpfeifer
I would not worry about it leaking like animalistic said as long as the surfaces were clean and dry you will be good.
Old May 25, 2008 | 11:34 AM
Xclimation's Avatar
Xclimation
Even though I still use a tad, I believe it is recommended now-a-days not to use sealant.
Old May 25, 2008 | 11:41 AM
flareside_thunder's Avatar
flareside_thunder
I think ya'll are right however I always use copper spray gasket.....not only does it make it easier because it's tacky and sticks to the surface......it gives me a littleless worry and stress.
JR
Old May 25, 2008 | 02:22 PM
mike L's Avatar
mike L
Thanks guys
Old May 26, 2008 | 10:21 AM
jonpfeifer's Avatar
jonpfeifer
Typically I like to use that copper coat spray adhesive just to help keep the gasket in place during assembly.
Old May 26, 2008 | 10:28 AM
BChance's Avatar
BChance
I use monkey snot (weatherstrip adhesive) to keep the gasket in place on the pump..apply to both, let dry, stick it right the first time, you don't get a second shot most times if you did it right.. then install..
But if you cleaned the surfaces well, and aligned the gasket right, your fine.
Old May 26, 2008 | 01:46 PM
brown 4x4's Avatar
brown 4x4
The factory doesn't use any sealant on the water pump or timing cover gaskets (lots of others too). My water pump has never leaked a drop. I replaced my timing cover gaskets last month and I used Ford gaskets which are very noticably higher quality than Napa or Carquest's Victor brand. I was very tempted to not use any but chickened out and did use a small film on them.
I've had trouble with my thermostat gasket (Carquest) leaking and I blame the RTV. It actually blew out last summer and I could tell the RTV had really weakened the gasket. I put another Carquest gasket in with RTV as that's all I could get when I needed it. It's seeping again now. It'll be Ford gaskets if possible for me from now on.
Old May 26, 2008 | 02:42 PM
F150xlt's Avatar
F150xlt
The factory service manual (Helms) recommends the use of a sealant for both the timing cover and water pump gaskets along with thread sealer on the threads of any water pump bolts that penetrate into a water jacket.
I've always used Permatex Type 2
Old May 26, 2008 | 05:01 PM
bluesman2333's Avatar
bluesman2333
On a used motor, you do not have the same advantages as Ford did on the sparkling new motor. I ALWAYS use Hi-Tack on Water pumps and hoses. I NEVER have leaks.
Old May 27, 2008 | 03:08 AM
TattooJim's Avatar
TattooJim
Right On
I ALWAYS use high tack. I just got my F-250 so not a bunch of wrench turning yet but I have always used hign tack prior to my new toy. Except for intake manifolds, thats a whole 'nother thread..........
1mickey1
1983 - 2012 Ranger & B-Series
Jan 23, 2014 05:43 PM
arkredneck
Jan 13, 2014 10:19 PM
chrono4
General Automotive Discussion
May 16, 2005 04:57 PM
