General Automotive Discussion
gaskets/gasket maker
Old May 9, 2005 | 08:57 PM
chrono4's Avatar
chrono4
i found out for the first time, that when you put gasket maker on gaskets, that you need to let it dry. i put a new water pump gasket on my 88, and when i got done i started it right up. i got two jets of water out of the pump mounting surface. now ive got to tear it all up and redo it with out the gasket maker. anyone else ever done this?
Old May 9, 2005 | 09:28 PM
Ford_Six's Avatar
Ford_Six
Not really, I usually put the gaskets in dry, but if the surface is questionable, I use hi-tack. I can fairly say I have never had a leak like that. One thing to keep in mind is that silicon is an excellent lube, and until the material dries, you've got a greased gasket that will pop out under any pressure.
Old May 9, 2005 | 09:31 PM
chrono4's Avatar
chrono4
thats what i figured happened, was the silicone was just giving the water a grease spot to go through. after it happened i realized what happeded. ill just have to remeber not to do that again.
Old May 9, 2005 | 09:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
Use your gaskets without any sealer.
Old May 11, 2005 | 09:06 PM
TigerDan's Avatar
TigerDan
Ah, here we go again with the wonders of silicone, the answer to all the world's problems. There's no need to use that stuff to coat a gasket, it's just for unusual sealing problems, or when no gasket is available, and should be used SPARINGLY. I just tore down a Chevy 454 that had about a week on the rebuild, the builder used a ton of silicone everywhere, even the sides of the intake manifold where there were perfectly good Fel-pro blue gaskets. I've never had such a difficult time getting a manifold off. The reason the engine blew after only a week? There was so much silicone used that a glob of it got sucked into the oil pump, plugging it and starving the bearings. Two bearings spun on the crank and then the rods let go. It was a mess...but it was only a Chevy, so, no loss. On gaskets like water pump and timing cover gaskets, I like to use the Permatex Hi-tack red spray-on sealer. You coat the gasket and the surfaces, (Watch that overspray) let it sit for about a minute and then stick it together. It acts as a gasket adhesive and sealer, never had a leak using the stuff. But it too has its proper place, not for every job. -TD
Old May 11, 2005 | 09:23 PM
chrono4's Avatar
chrono4
yea, hard lesson learned. this weekend i got to tare it apart.
Old May 16, 2005 | 04:57 PM
rebocardo's Avatar
rebocardo
On waterpumps or thermostat housings I use the special Permatex for coolant. I lightly smear the gasket and apply it to the block and then torque to spec. Sometimes I use the red RTV. Never a problem.
obscurity
Jun 12, 2013 09:34 PM
Schuyles
Mar 30, 2012 05:47 AM
WRECKTEC
16
Jan 25, 2007 03:14 PM
b4hntn
1978 - 1996 Big Bronco
Jul 2, 2006 05:43 PM
