Thrown Code? Help!!
Old May 24, 2008 | 08:46 PM
Stroked Out!'s Avatar
Stroked Out!
Thrown Code? Help!!
i HAVE A CODE THAT CAME UP ON MY SUPERCHIP TUNER P0284 CYLINDER 8 CONTRIBUTION/BALANCE FAULT WHAT THE HELL DOES THAT MEAN THEN I CHECK AGAIN A COUPLE WEEKS LATER AND IT DIDNT COME UP AGAIN. HELP I AM WORRIED
Old May 24, 2008 | 08:53 PM
brickie's Avatar
brickie
Sounds to me like #8 starved for fuel,its the last hole to get fuel.You should keep an eye on fuel pressure if want to keep that injector.A cross over line and a gauge will save you worrying about it.
Old May 24, 2008 | 09:01 PM
Stroked Out!
What Is Exactly A Cross Over Gauge?
Old May 24, 2008 | 09:10 PM
brickie's Avatar
brickie
Cross over line connects the fuel lines that are inside the heads with a fuel line between the two heads at the back of the motor. The gauge is a pressure reading from your fuel system to keep an eye on the pressure from inside the cab. At the very least you will know when to swap out the filters. When was the last time you changed the fuel filters?These motors do not like dirty filters or fluids.
Old May 24, 2008 | 09:12 PM
Stroked Out!
When I Got The Truck At 48k Now 84k, Is That Something I Could Takle Or Leave To The Pros And About How Much Am I Looking At?
Old May 24, 2008 | 09:16 PM
brickie's Avatar
brickie
Use the search feature,tons of info and places to get ford (racor sp?) filters.If I were you I would get on top of getting filters done pronto.
Old May 24, 2008 | 09:24 PM
Stroked Out!
How Much Is The Cross Over Cost?
Old May 24, 2008 | 10:13 PM
doubledee715's Avatar
doubledee715
you've probably already done damage to that injector and possibly others by going that long on your fuel filters. cross over line is abour 100 bucks....labor is a pain in the *** from what I hear though.
