A/c troubles
Old May 19, 2008 | 10:50 PM
hott-rodd's Avatar
hott-rodd
A/c troubles
My A/c blow cold then stops for no reason, I get hot air.
When the air stops the compressor is stopped also.
The pressure is around 42 psi when compresor running, 100psi when not.
Sometimes its cold all day, sometimes 10 minutes.
If I turn it off for a few minutes, usually it resets.
I tried to bypass the safety switch in the dryer, didn't help.
What am I looking for?
Old May 20, 2008 | 09:43 AM
hott-rodd's Avatar
hott-rodd
Where is the head unit, how much does it cost, and how hard is it to repalce?
Thanks
Old May 20, 2008 | 05:05 PM
tasaro's Avatar
tasaro
Just watch out! i just got stranded & acutally had to tow my truck home because mine was doing that, i thought it was ok 'cause it would still work after turning on/off, then (i'm still not sure how) the pulley on my AC compressor siezed. At first i thought the
battery(ies) were dead, because the engine would barely turn over but it was the pulley not turning.
I don't know anything about AC systems, so i don't know if my problem was different from what you guys are experiencing but it sounds the same.
Old May 20, 2008 | 10:47 PM
hott-rodd's Avatar
hott-rodd
Are you saying the Head unit is the Compressor?
Old May 21, 2008 | 08:26 AM
69cj's Avatar
69cj
Apples and Oranges here guys. Mechanical compressor vrs. electronic A/C control.
Old May 21, 2008 | 01:53 PM
tasaro's Avatar
tasaro
I just wanted to make the point that it may not always be the head-unit. The warm/cold issues could be indicative of a more serious problem. I also happen to live in the hot-*** desert so may AC problems may be unique to my location.
Old May 21, 2008 | 02:50 PM
hott-rodd's Avatar
hott-rodd
Thanks, I didn't think so but sometime we have different names for the same thing.
Where is the head unit, how much does it cost, how hard is it to replace?
ANYBODY?
Old May 21, 2008 | 02:58 PM
69cj's Avatar
69cj
Mine was replaced under warranty so I have no idea what one would cost.
Old May 25, 2008 | 01:59 AM
hott-rodd's Avatar
hott-rodd
bump for tech help.
UncleRedBuck
Jun 9, 2016 10:39 PM
jeffrey5679
May 8, 2013 09:29 AM
BigBadBob
2011 - 2019 Explorer
Jun 28, 2012 07:04 PM
TR6
Jul 25, 2009 04:57 PM
mechman787
1997 - 2003 F150
Jul 19, 2008 06:04 PM
