460 alternator bracket assembly
Old May 24, 2008 | 06:40 PM
hp246's Avatar
hp246
Anyone with a pic or a diagram of a 460 alternator bracket assembly?
Old May 24, 2008 | 07:42 PM
19704X4F250's Avatar
19704X4F250
How's this?
100 amp alternator, large bolt on the bottom with spacer, adjustment bracket on top that bolts to water pump. Simple huh?
Old May 24, 2008 | 08:16 PM
hp246's Avatar
hp246
Quite a bit different than what I have. I have an adjustment bracket, a second larger bracket and two spacers. Trying to figure out how it all goes together. Looks like the adjusment bracket goes on top, gotta figure out how the other bracket attaches and how the alternator attaaches to that bracket. I want to make sure all of the pulleys line up when this is done.
Old May 24, 2008 | 09:58 PM
mark a.'s Avatar
mark a.
What are you puting it into ?
Old May 24, 2008 | 10:50 PM
fasthauler's Avatar
fasthauler
Here is a stock 1977 F250 with a 460. If this is not it then specify what you have.
Old May 24, 2008 | 11:09 PM
hp246's Avatar
hp246
Thanks WB. Exactly the pics I was looking for. I'm putting together a motor to put in a 76 F100. It used to have a 360 resting between the rails. Had the motor built from scratch, so am trying to figure out some accessory mounting issues.
Old May 25, 2008 | 09:30 AM
fasthauler's Avatar
fasthauler
Glad I could help. Good luck on your install.
nichc
Sep 15, 2014 11:54 AM
crazyredneckanyhow
West Virginia Chapter
68
May 10, 2013 07:20 PM
JB78f150
Apr 21, 2012 01:56 PM
mositso
Engine Swaps
13
Mar 7, 2010 07:30 PM
