Frozen Spindle!
Old May 24, 2008 | 05:52 PM
93tankus's Avatar
93tankus
Frozen Spindle!
Hello All,
I've got a '93 F150 XLT 4x4 with the Dana 44 front end. I'm trying to replace the ball joints. I've hit a snag trying to remove the spindle. I removed the 5 spindle nuts, but it just seems to be frozen on there solid. I've beat and banged on it for a bit with my rubber mallet, and it's been dosed good with penetrating oil.
I called the local stores to see if they have a spindle puller tool, but nobody seems to have one. Besides trying to bang the heck out of it, does anybody have any other ideas? Heat it up?
Thank you all in advance!
Old May 24, 2008 | 06:07 PM
ssidney's Avatar
ssidney
little bit of heat
Old May 24, 2008 | 06:11 PM
danr1's Avatar
danr1
I use a slug hammer (a big heavy one) and a few solid blocks of wood, do not hit the spindle itself with the hammer. When the wood splits, use a new piece!
1 or 2 good solid hits will drift it to one side, knock a screwdriver into the gap between the spindle and knuckle, then drift the spindle the other way. Keep shimming the gap drifting it side to side as you go until its out of the hole.
Just be sure not to hit the very end of the spindle, you will make it out of round and not be able to get the wheel bearings and or nuts back on.
Penetrating oils won't help, the spindle is a press fit in the hole.
I've done many of them, never even seen a puller.
Old May 24, 2008 | 07:56 PM
alz's Avatar
alz
I believe AutoZone sells/rents a spindle puller adapter for a slide hammer.
AutoZone.com | Shopping | Accessories | Product Detail - Great Neck 4WD Spindle Puller
Old May 24, 2008 | 08:28 PM
rowdyredneck's Avatar
rowdyredneck
That's what I use at work. Just attach it to a big slide hammer and they pop right off. Before I had access to one of those I used to carefully work around the edges with a chisel, but be very careful not to gouge the spindle or steering kunckle. I usually wire brush the spindle and coat it with anti sieze before installing it back on the truck.
Old May 25, 2008 | 06:52 AM
Lazy K's Avatar
Lazy K
I`m with rowdy and a big chisel.
BroncoBilt
1978 - 1996 Big Bronco
13
Nov 13, 2014 06:35 PM
djmichael24951
Mar 6, 2014 08:55 PM
PKIi
1983 - 2012 Ranger & B-Series
Jun 30, 2013 04:29 PM
crownver
19
Oct 18, 2009 02:33 PM
rduck747
Feb 10, 2005 10:37 PM
