92 F350 spindle removal problem
Old Feb 10, 2005 | 12:53 AM
rduck747's Avatar
rduck747
Hi, trying to replace ball joints on rt front. Everything went well till trying to remove the spindle.
After removing the 5 bolts, shouldn't it just come loose?
I've banged and banged, no use.
Is there a special tool or something I'm missing?
Thanks Ron
Old Feb 10, 2005 | 07:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Ron...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 10, 2005 | 08:25 AM
51frrdtrk's Avatar
51frrdtrk
Yes there is a special tool for removing. I purchased one at my local parts supplier (Murreys) it is a threaded scocket style tool that threads onto the end of the spindle and then you use a slide hammer to pull it off. It will take a lot of pounding to get off.
While using the slide hammer i have also applied heat with a torch to the upper side of the hub on the rear side. Keep the torch away from the ball joint and also away from the rear dust seal. I will assume that you are replacing the rear dust seal, but there is a small plastic seal hidden inside the seal.
Old Feb 10, 2005 | 09:24 AM
rduck747's Avatar
rduck747
Thanks for the info...my parts supply guy didn't know that.
I'll give it a try and give it another bang.
Ron
Old Feb 10, 2005 | 10:37 PM
rduck747's Avatar
rduck747
Update...job complete. The spindle puller socket worked great. Didn't need heat.
The auto parts store allow a 3 day loner kit on the slide hammer and ball joint puller kit.
thanks again...Ron
MONAVIERONJON
Aug 30, 2011 08:40 PM
351slug
Offroad & 4x4
17
Jul 18, 2009 12:37 PM
93tankus
May 25, 2008 06:52 AM
yellow78ford
Mar 23, 2007 08:18 AM
