Transfer Case trouble, need help please.
Old May 26, 2008 | 10:11 PM
Grey89F250's Avatar
Grey89F250
Originally Posted by helifixer
all of the 1356 transfer cases I have rebuilt that won't stay in 2 high had damaged range selector gears. (the gear that the fork moves with the little white plastic bushings) the gear seems to fail due to a plastic clip breaking and the fork not pushing the gear in all the way. once it starts popping out the gear is pretty damaged. don't order parts until you have it apart to see if it is pre mod or post mod range selector. (31 teeth or 38 teeth) also plan on an oil pump rebuild. and repair the case where the pump rides.
Thanks man, I just got off the phone with my dad and he said the same thing you just said. If it popping out of gear, you probaly got worse damage. Im going to hit the local pick and pull tomorrow. If they got a Tcase Im just gonna buy it and keep this one to rebuild and keep as spare. Once I get done with truck(sometime in the next 50-60 years) Ill need it. LOL **** happens.
Old May 27, 2008 | 11:55 AM
helifixer's Avatar
helifixer
there has been some on e bay also.
