flex plate?
Old May 25, 2008 | 10:07 PM
Sandman1991's Avatar
Sandman1991
flex plate?
will a flex plate from a 302 bolt on to a 351w
Old May 25, 2008 | 10:53 PM
Conanski's Avatar
Conanski
Yes, but that's what you need to worry about. It has to have the right balance weight and the right offset for the tranny it will get bolted to. If the balance isn't right the motor will vibrate, and if the offset isn't right you'll destroy the tranny oil pump the first time the motor is fired, and that will send steel shavings throughout the tranny.. bringing about a tranny rebuild before you leave the driveway. Make absolutely sure you have the right flexplate for the job.
Old May 26, 2008 | 07:52 AM
nintey4f150's Avatar
nintey4f150
what would the right flex plate be for a 351w with a 4r70w trans cause im goin to be doing that swap sometime this year
Old May 26, 2008 | 09:55 PM
Sandman1991
well im gonna be running a 351 with a e40d so i need a flexplate from any truck with a 351w and a e4od
Old May 27, 2008 | 07:39 AM
Conanski's Avatar
Conanski
You may have to reconsider, I don't think that combo was ever put together by the factory, so there is no flywheel.
Old May 27, 2008 | 12:33 PM
alz's Avatar
alz
Conanski, don't you run this combo. Even though you run an AOD, isn't that the same as the AODE or 4r70w?
You used one from a Crown Vic or Grand Marquis, right?
Old May 27, 2008 | 12:55 PM
Conanski's Avatar
Conanski
I have the 5.8 and the old fully mechanical AOD.. and that exact combo was available from Ford in the Police Crown Vic, so that flexplate exists. The AODE/4R70W could probably use the same flexplate, but I don't know how similar these trannys are. On the TCI web site they offer parts and kits for the 4R70W with a 5.8 which is interesting, maybe these guys or Baumann Engineering could say what flexplate is needed.
