carb id numbers
Old May 24, 2008 | 11:03 AM
amstone's Avatar
amstone
carb id numbers
Could somebody tell me what this Motorcraft carb model is? Thank you.....
Numbers on tag
E5TE-ZB C 7D 1
Number on carb
E5TE95107B
50264-1
0927
Thanks again
Old May 24, 2008 | 11:08 AM
amstone's Avatar
amstone
guess maybe more info might be needed...Want to change the power valve and don't know number. It has 61 primary jets and it is on my 5.8HO 1986 F150 4X4. Runs so rich it burns the eyes but no black smoke. not fouling mplugs but I'm sure it won't pass WA. state emissions.
Old May 24, 2008 | 01:23 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
looks like you have all that you really need.
Go to your favorite auto parts store, and ask for a rebuild kit and/or a power valve for a 1986 F-150 4x4, with the 5.8L, with carb tag number E5TE-ZB.
They should be able to set you up.
Old May 24, 2008 | 04:44 PM
Piffery1's Avatar
Piffery1
I'm pretty sure it's a Motorcraft by Holley, 4180C-4V. Probably needs a power valve. There are a number of different power valves for the 4180's and its important to get the correct number for your particular application for best performance. The part number E5TE-9510-ZB or the Holley list number 50264-1 should be enough for a competent counterman to identify the correct power valve number. These are two-stage valves and usually run $25-$35 depending on where you buy.
Old May 24, 2008 | 05:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E5TE-ZB
E5TE-9510-ZB = E5TZ-9510-Z .. Holley 4V Carburetor / 1980/89 Ford Light Truck Parts Catalog / Section 95 / Carb Parts List #5H.
When one has the carb tag number, one can get the correct carb parts list number.
Carb kit: E5PZ-9A586-KA (Motorcraft CT-1443-A)
Power Valve p/n (included with carb kit): D5PZ-9A565-A (Motorcraft CE-120)
Any autoparts store can cross the above Motorcraft #'s over to the brands they sell.
Old May 24, 2008 | 05:48 PM
amstone's Avatar
amstone
thanks alot would you turn the idle mixture screws in or out to lean it at idle.
Old May 24, 2008 | 07:06 PM
Piffery1's Avatar
Piffery1
In-but you have to remove the caps over the screws to get to them. Which means removing the carburetor. On some you can drill a small hole in the cap and screw in a sheet metal screw then, pull on it with pliers. Others you saw the carburetor base around the cap to get them out. But in my experience that's not likely the problem anyway, more likely the power valve leaking or the float levels set too high or choke not opening fully. Usually with age, deposits form in the idle passages which tend to lean the mixture rather than richen it. If you do plan to adjust the mixture, count/record the number of turns "in" to lightly seat the screws so you can go back to the original setting if you need to. OBTW, the mixture screws on these have Allen heads rather than slots.
rob8210
Ford Truck Parts for Sale
Jan 31, 2018 11:01 PM
CamoLaw
Nov 13, 2010 01:34 PM
SmallBlockV8
Jul 8, 2010 09:17 PM
clinicalphd
Dec 16, 2008 08:39 PM
jc78
May 26, 2001 06:38 AM
