Power Curve
Old Feb 11, 2002 | 06:48 AM
TallPaul's Avatar
TallPaul
Power Curve
Canzus: I notice in the Chilton manual there was a 1600 cc four in the Escort through 1985 (forgot to look if OHC, but probably).
Anyway, while in the Chilton manual I looked up the 1.9:
The 1995 1.9 four is rated 88 hp @4400 rpm and 108 lb-ft @4000 rpm. Interestingly, the same engine in 1986 put out 108 hp @5200 and 114 lb-ft @4000 with MFI. The '95 is SFI, but same figures as '95 occur in '92 with MFI. Now the 1.8 DOHC in '95 put out 127 hp@6500 and 114 lb-ft @4500.
I suspect these small fours don't have a lot of pulling power much below about 3000 or so.
Old Feb 11, 2002 | 05:29 PM
canzus's Avatar
canzus
Power Curve
The early 80's 1.6L was the same design as
the 1.9L CVH in the later ones...
Little engines require rpm to make power,
I have a couple of 2.0L EAO's that put out
over 150fwhp, but don't come up on the cam
until about 3500rpm, many years ago I had
one with a draw through turbo SWMBO used to
hunt Camaro's with, Bit of a bitch to start,
but made about 230rwhp at 6500rpm...it was
very entertaining when it came up on the cam
and boost at the same time...
Steve & the Rockette
Old Oct 7, 2002 | 06:45 AM
TallPaul's Avatar
TallPaul
Power Curve
>Fun facts to know & tell...
> The EAO 2.0L OHC from the 71 to 74 Capri
>was used in the Pinto from the same era,
>hence the "Pinto" moniker.
>The push rod 1.6L is still being made today,
>for industrial power plants, as a 1.3L and
>1.6L. The "Pinto" 2.0L was available in
>Europe as a 1.6L also, and is the basis for
>Formula 2000 in this country. The "Lima"
>range of OHC engines include the 2.0L, 2.3L
>and 2.5L from the Ranger PU's have nothing in
>common with the EAO's, other than they were
>both OHC Ford engines...
>Confused yet?? Don't get me started on Lotus
>Variants of the EAO's...
Interesting. I got a used manual for the '81-'85 Escort and it shows a 2.3L pushrod four in '83-'85. Then turning to my Aerostar maunal, which starts in '86, and the 2.3 four is an overhead cam. So Ford must have had a plethora of four bangers over the years. Now a Ranger with the 2.5L pushrod four would be something to get my hands on someday. What years did the 2.5L run in Rangers?
Old Oct 7, 2002 | 05:15 PM
canzus's Avatar
canzus
Power Curve
[updated:LAST EDITED ON 07-Oct-02 AT 06:17 PM (EST)] You're right, the 2.3L and 2.5L pushrod
engines are based on the 200/250cid I6,
also known as the "HSC", IIRC there was
also a HSC "HO", and were available from
the mid 80's to the mid 90's, good little
engines, they came in the Tempo/Topaz also...
The 2.5L OHC started in '97 or '98 I think,
don't quote me on that, I may be wrong...
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6, That blowed up real good...
'01 ZX2 (No Mods yet)
Old Oct 9, 2002 | 06:01 PM
96f150's Avatar
96f150
Power Curve
Smidgy
2015 - 2020 F150
Mar 20, 2015 09:36 AM
Mr13mcgoo
16
May 31, 2009 02:55 PM
jimrat
Modular V8 (4.6L, 5.4L)
Aug 18, 2005 09:35 PM
1978Crew
Sep 7, 2004 08:10 PM
dhag911
Jun 6, 2004 01:09 AM
