proportioning valve conversion
Old May 24, 2008 | 07:44 AM
FLN's Avatar
FLN
im converting my 68 truck over to disc brakes using the 73-79 set up.the brakes are off a 74 but the proport. valve is off a 78 f150.will this work? and does it matter where on the chassis its mounted? i want to use the location of my original but this one was mounted closer to the master cyl.
Old May 24, 2008 | 11:07 AM
jowilker's Avatar
jowilker
Yes the 78 will work (should be same). I don't know that any specific place is required. Mine currently is above the steering gear, if I do another conversion I will mount it on the chassis rail more out of sight.
John
Old May 24, 2008 | 04:37 PM
FLN's Avatar
FLN
another ?. should i reuse the kingpins & bushings from the donor truck or can i just use new kingpins.they seem fine,but want to do it right.can the brass bushings be driven out by myself.
Old May 24, 2008 | 04:54 PM
jowilker's Avatar
jowilker
Unless the kingpins are sloppy, I leave them the hello alone and swap the complete I-beam. It is much simpler in the long run. IMHO
I have done, and been a part of several swaps. I don't want to get king pin ugly unless I have to.
John
Old May 24, 2008 | 06:45 PM
FLN's Avatar
FLN
kingpins
ive already driven them out.i beam was bent.pins look fine.can you reuse them after taking them out.? i appreciate your help.
Old May 24, 2008 | 08:09 PM
DarkWolf40's Avatar
DarkWolf40
King pins are as easy as a NAPA machine shop away, take you I beams to them and pick then up later with new brass busings reams and honed. Make it handle like new again thats for sure.
Old May 27, 2008 | 12:58 AM
wildwes's Avatar
wildwes
I have a question along the same lines- is it necessary to swap the proportioning valve out at all when converting from manual drums to manual discs, or can you simply leave the original proportioning valve, since the master cylinder will be the same?
thanks
Old May 27, 2008 | 05:17 AM
jowilker's Avatar
jowilker
wildwes, All drum brake systems don't have a prop. valve.
The disc brakes require a different flow rate and pressure than the rear drums so a porp. valve is needed to divide it up properly. You will have to use it with disc/drum systems.
John
Old May 27, 2008 | 10:06 AM
wildwes's Avatar
wildwes
Thanks, brakes aren't really my thing, I can reline them just fine, but the actual mechanics of the brake system aren't my thing. I usually deal more with the drivetrain.
Old May 27, 2008 | 07:14 PM
DarkWolf40's Avatar
DarkWolf40
Never heard of manual disc brakes except on really old sports cars. I wouldn't think that would work very well on a big Ford Truck. I know on my conversion from 67 F250 power drums to 76 F250 power discs I still need to change the master cylinder and prop. valve.
Old May 28, 2008 | 06:45 AM
DavidB's Avatar
DavidB
Well, I guess a '66 Mustang GT could be considered a "really old sportscar".
I like the manual disk brakes. They work great, but then , except for the maintenance, I am happy with the 4 wheel drum brakes on my '70 F100.
high6
Sep 6, 2016 01:23 AM
vidaliaman
Mar 30, 2016 07:46 AM
mccolalx
Sep 18, 2015 11:12 PM
mhopkins
18
Apr 9, 2009 07:54 PM
Gargamel
1983 - 2012 Ranger & B-Series
Sep 3, 2003 10:15 AM
