Tri doors open, LIGHTS OFF!! problem SOLVED!!
Old May 24, 2008 | 01:23 AM
Daviddc114's Avatar
Daviddc114
i found the wire! it is right next to the fuse panel (left side) you must take the 4 screws off the fuse box, 2 on top, and 2 on bottom, you must push up on the fuse box (carefully) to clear the 2 bottom bolts out of the holes, move it over to the right (passengers side) about 1 or 2 inches, then on the left side of the box, between it and the left side of the dash, you will see a bunch of wires,
in my 2000 limited v-10 it was all white, be sure to test it first with a multimeter, you must shut all doors when testing it, even drivers, so close the lastch on the drivers door to trick the system. the reason for this is the rear hatch is tied in with the ALL DOOR TRIGGER, so if there if ANY door is open you wont be able to test for the rear hatch. once you find the all whit wire and you make sure you got the right one, extend the wires a little bit and put it on a rocker switch! AWSOME MOD! i just went to the drive in and i got to go in and out through the tri door and i could leave it open, all with no lights coming on!!! here is the round rocker i chose, 3 dollars at walmart, i think it looks REALLY nice, if you like it and cant find it anywhere PM me, i have a few extras..
Old May 24, 2008 | 02:45 AM
Monsta's Avatar
Monsta
Sit. Stay.
Hey! Nice light switch! Need another? I've got one you can have for shipping.
So, you can now open the hatch without the lights coming on? Cool!
Old May 24, 2008 | 09:25 AM
Daviddc114's Avatar
Daviddc114
yes sir, and its not hard at all, i recomend this mod, VERY simple, and very handy.
Old May 24, 2008 | 12:27 PM
ukmat71's Avatar
ukmat71
so does this just keep the lights from coming on when you open the rear hatch ?
and does it still let the lights come on when you open any other door?
the amount of times my battery has died , because i keep opening the tailgate glass to get something in/out, this mod sound great .
Old May 24, 2008 | 02:28 PM
Daviddc114's Avatar
Daviddc114
yes the other doors will still activate the light, but the rear hatch will not trip the light at all when the switch is off, when the switch is on you will resume normal operation, WORKS AWSOME!!
Old May 24, 2008 | 02:40 PM
ukmat71's Avatar
ukmat71
great stuff, i will try this next week, hopefully the wiring will be the same in my xlt of the same year.
i think theres about 12 lights that come on when the doors are open. dont know why ford didnt put an override switch in, they must have have loads of complaints about batterys dying
Old May 24, 2008 | 03:21 PM
Monsta's Avatar
Monsta
Sit. Stay.
David, do you need another headlight switch?? I have one for free (for you) if you do.
Old May 24, 2008 | 04:29 PM
Daviddc114's Avatar
Daviddc114
that would be sweet!!! my stupid switch keeps falling off!! (as you can see) thanks!!!
Old May 24, 2008 | 04:34 PM
aortizexcursion's Avatar
aortizexcursion
I believe there was a recall for the switch. I guess your Excursion never had the recall performed.
Old May 25, 2008 | 02:42 AM
Monsta's Avatar
Monsta
Sit. Stay.
Tru dat! See if the dealer will give you new one first. If not, PM me and I'll send it out to you.
elgemcdlf
277
Dec 19, 2018 12:29 AM
gdub
54
Feb 10, 2016 10:43 AM
GreatNorthWoods
21
Oct 10, 2012 09:46 AM
Herbiehusker
13
Aug 1, 2010 10:54 AM
Riffraff Diesel
108
Jul 27, 2009 09:28 PM
