Sponsored by: Real Truck
4.88's too much?
Old May 23, 2008 | 06:48 PM
99_F250_SD's Avatar
99_F250_SD
4.88's too much?
I have a 99 f-250 Sd 5.4 5 speed manual with 35s and i am thinking about putting 4.88 gears in it, is it a little over kill?
Old May 23, 2008 | 06:55 PM
350z's Avatar
350z
I was thing that would be a good gear ratio also !
Old May 23, 2008 | 07:35 PM
cartmanea's Avatar
cartmanea
That would be about right for 38s. Running those gears with 35s will kill your hwy mileage. You should probably go with 4.30s or maybe 4.56s.
Old May 23, 2008 | 07:42 PM
ReAX's Avatar
ReAX
It's too much for my taste, but should have great acceleration. It all depends on your typical cruise speed and how many RPMS you want to turn doing it.
Old May 23, 2008 | 08:42 PM
bigjake0524's Avatar
bigjake0524
I did 4:88's with my F-250 with a v-10 and it was too much gear for the 35's wold have been perfect for 38's I would look at the 4:30 or 4:56, Yukon makes very good gears if you are also shopping for brand.... Good luck.
Old May 24, 2008 | 11:46 AM
Ace!'s Avatar
Ace!
It's never enough until your heart stops beating.
Old May 24, 2008 | 04:15 PM
Green Ford's Avatar
Green Ford
I was running 4.88's with my 38's and now with my 41's makes a big difference with tires of that size but with smaller tires it would be a little much unless your drag racing....
Old May 24, 2008 | 07:25 PM
pagnew's Avatar
pagnew
4:30's w/ V10 are perfect with 33's (stockers). The will be VERY good with the 305/70/18's (35", BUT a wee bit wider than stock).
If I were to go with 325/65/18's (35" and fairly wider than stock) I'd still be happy with 4:30, but may think 4:56.
That's the limit...anything larger and it's 4:56 and up!
1955 f250
Oct 14, 2014 09:24 PM
Ryan313
Dec 22, 2013 06:44 PM
jrproper
Ford Truck Parts for Sale
Dec 19, 2013 06:50 PM
mjb1962
Jan 27, 2004 04:04 AM
