Power Brake Distribution Block
Old May 23, 2008 | 06:39 PM
BushyTea's Avatar
BushyTea
Well glad to be back working on the truck. Got swamped with work and never got to finish the power brake conversion.
However last I left off I had a proportioning valve but was having no luck finding all the adapters and such to make lines fit so I started searching around today and found this SSBC Brake Distribution & Proportioner.
Has anybody used this or had experiance with it? Seems perfect with the 3/16" size for all the lines plus the built in sensor for brake pressure to activate the taillights.
Here is a link to more info:
Performance Disc Brake Search Results from Stainless Steel Brakes Corporation (SSBC)
Any thoughts/ideas would be great.
Thanks!
Mike
Old May 24, 2008 | 12:34 AM
jhooch's Avatar
jhooch
What is your proprtioning valve off of. If it is O.E. Ford you shouldn't need any adapters, just the lines from the donor. I just mount the valve in the same location as it was on the donor. Good luck!
Old May 24, 2008 | 08:53 AM
bwilliams7527's Avatar
bwilliams7527
If you're not going to use the lines from the donor (not recomended), cut the lines close to the proportioning valve. This way you get the connectors to use when you fab up your new 3/16 lines. I know what you are talking about. I noticed two of the plugs were different sizes when I went to get my parts. The lines are still 3/16, they just have different size connecting plugs.
Old May 24, 2008 | 11:53 AM
BushyTea's Avatar
BushyTea
Thanks guys, I do know about just taking the lines off the donor truck but I do not physically have the donor truck with me and getting junkyards in my area to take time to pull small parts like the lines just isnt' something they typically want to do. Most here do not even let the customer to into the yard to pick off their own parts.
I already have all my new lines built so was just looking for a solution to having to find adapters that do not exist in any of the stores I have checked locally plus for a cleaner look. Having adapters all over the setup just isn't very clean.
Appreciate the help guys and hope to have my 66 back on the road soon.
RACERX7775
Jul 13, 2017 10:59 AM
slack_master
Oct 26, 2016 11:29 AM
7.3 Ex
Aug 28, 2016 11:19 PM
F350-6
19
Jun 29, 2015 07:24 PM
CivilianTank
May 17, 2015 04:36 PM
