10k problem
Old May 23, 2008 | 02:23 PM
1950gmcelc's Avatar
1950gmcelc
10k problem
I just the 10k mod a few days ago and now ever once and a while my speedo starts to jump and my subs started making a weird noise but only sometimes. I am running a hypertec chip already that came with the truck so i don't know if i even need the 10 k mod or not. I also tried the 14.7k mod but at about 2500 RPM the truck would hit a wall and would not go anyfurther past the 2500 mark. So I pulled it out and went back down to a 10k but it studers at 3000 rpm and ideas.
Old May 23, 2008 | 03:57 PM
tjbeggs's Avatar
tjbeggs
if you remove the mod does the problem stop?
Old May 23, 2008 | 06:07 PM
1950gmcelc's Avatar
1950gmcelc
I haven't noticed the speedo problem with the risitor off but I still get the sub noise
Old May 23, 2008 | 06:13 PM
1950gmcelc's Avatar
1950gmcelc
hey tj you have pictures of a 95 gauge panel that you turned white where did you get the cover?
Old May 23, 2008 | 06:27 PM
tjbeggs's Avatar
tjbeggs
neither of those issue seem to make sense with a 10K mod? I am not really sure what to think. I guess I would try to put it back in and see what happens. Also Check the speed sensor on the rear diff. Maybe coincidence that two problems started when you installed the mod.
Procarparts.com
I actually had the silver one in the 95 and I liked it much better than the white one in the link (also in my current truck). Can't seem to find the silver face any more but it didn't have the solid blue in the center of the two large gauges.
Old May 23, 2008 | 06:39 PM
Action4478's Avatar
Action4478
He's getting old (er ) and it's harder to see where he's going at night .... ...
Old May 23, 2008 | 06:42 PM
tjbeggs's Avatar
tjbeggs
Quit picking on me!! Actually the overlay is too bright! with that and my gauges turned all the way up my kids can read their book in plain light in the back seat!! If I cut holes in my floor it would look like I have neon' under my truck!
Old May 23, 2008 | 06:45 PM
Action4478's Avatar
Action4478
....Hmmm....
Old May 23, 2008 | 09:21 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the sounds from the subs sounds like a ground problem as does the speedo. can you describe the sound?
Old May 23, 2008 | 10:57 PM
1950gmcelc's Avatar
1950gmcelc
kinda sounds like a jake brake out of the subs
Old May 24, 2008 | 01:15 AM
1950gmcelc's Avatar
1950gmcelc
I pulled the risistor off this afternoon and noticed a loss in power and acceleration speed but with the risitor in It would rev faster but under a load it would stumble. No risitor no stumble but slower acceleration. Any ideas?
Old May 24, 2008 | 07:37 AM
c00nhunterjoe
subs definatly sounds like a ground,
resistor could be injector related, a 10k shouldnt have any problems in any truck. did you get the 1/4 or 1/2 watt resistors? if you picked up a diferent style it may cause the problem. make sure you got a good connection.
Aragas
Modular V10 (6.8l)
Sep 21, 2014 06:09 AM
timmosazz64
Mar 3, 2013 08:27 PM
Tim Young
Feb 25, 2011 08:27 PM
cowmilker08
24
Apr 18, 2010 08:12 PM
Pikachu
15
Jul 15, 2004 08:17 PM
