1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Remote fob for 2001 F250
Old 05-23-2008, 05:42 AM
darmar43's Avatar
darmar43
darmar43 is offline
Hi, I just got this truck and it has auto door lock and power windows but no remote. How can I tell if it is wired for a remote? If so, can you help me with the programing steps for a remote?
Thanks,
Dave
Old 05-24-2008, 10:53 AM
Budman1962's Avatar
Budman1962
Budman1962 is offline
You can get the remote on ebay. When people trade or sell there pickups they take the remotes and manual and sell them on ebay. I think if it is a XLT or Lariat it should have a remote.
Budman
Old 05-24-2008, 10:57 AM
Budman1962's Avatar
Budman1962
Here is an online dealer.
Keyless Remotes Online
Old 05-24-2008, 11:55 AM
darmar43's Avatar
darmar43
darmar43 is offline
Thanks, does anyone have the programing instructions?
DAve
Old 05-24-2008, 12:04 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Have all of the transmitters available before you begin. A maximum of four can be programmed.
1. Ensure that the vehicle is unlocked (all doors)
2. Put the key into the ignition. This position is known as the number 2 position.
3. Turn the key to the "OFF" or number three position. (clockwise)
4. Cycle, eight times, rapidly (within 10 seconds) between the 3 (OFF) position and the 4 (ON). Note: The eighth turn must end in the 4 (ON) position.
5. The doors will lock and then unlock, to confirm that the programming mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter. Note: If more than 20 seconds have passes you will need to start the procedure over again.
7. The doors will lock, then unlock, to confirm that this remote entry transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 3 (OFF) posiiton after you have finished programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming mode has been exited.
Old 05-24-2008, 12:27 PM
Rongold's Avatar
Rongold
Rongold is offline
Before you buy anything, try the procedure in step 4 above. If your doors lock & unlock, you have remote entry. If they do nothing, then your truck is not equipped with it.
RON
77_150
03-16-2015 05:05 PM
tem00
2009 - 2014 F150
12-02-2010 09:55 PM
darmar43
05-28-2008 08:10 PM
2funride
12-03-2006 05:46 PM
kab_slc
1997 - 2003 F150
07-06-2003 05:19 PM
Quick Reply: Remote fob for 2001 F250
