Fuses To Pull To Kill Engine?
Old May 23, 2008 | 11:41 AM
Johan01's Avatar
Johan01
Which relay is it for an early 99? I can't find my owners manual and the haynes book doen't have a diagram.
Old May 23, 2008 | 12:39 PM
TxFordGuy's Avatar
TxFordGuy
i like this idea but has anyone ever chose a different fuse. if someone broke in my truck i wouldn't want them cranking and cranking on it, as they burn up my starter and drain my batteries. Isn't there a starter relay or fuse you can tie to so that when that try and kick it over, nothing happens??
Old May 23, 2008 | 12:41 PM
TxFordGuy's Avatar
TxFordGuy
Also, what does the no-start option on DP tuner disable?? Haven't bought it yet so i don't know
Old May 23, 2008 | 01:01 PM
BanksPSD's Avatar
BanksPSD
I'm not sure what the no start is but I'm sure it just wipes the PCM clean.
Old May 23, 2008 | 01:03 PM
BanksPSD's Avatar
BanksPSD
I never really looked into the other fuses, I read about this mod and did it...
Personally, I'd rather them burn up my starter then them take my truck!
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
You hold both buttons on the DP, the light flashes on 0 but will not go to position 0 till you turn off the key. Then to get outta 0, you have to tun the key on, hold the right button 3 seconds and it goes back to position 1. I did my reading last night haha after i got it installed
Old May 23, 2008 | 01:05 PM
STROKIN'IT7.3
Ok misread that. Not sure but i'd assume it cuts power to the injectors. Haha but now you know how to get to 0 haha
Old May 23, 2008 | 04:59 PM
DaveWilliams's Avatar
DaveWilliams
Or just remove the switcher box
When I was thinking about trying this mod, I have the DP with no start. I just pulled the swtich box and it will not start either. I pulled the IDM relay and it would not start so either one is a good way to keep your truck.
Old May 23, 2008 | 05:07 PM
DaveWilliams
Talking
You must have a newer version than what I have. I just now got back in from trying this NO START....you are right about holding both buttons makes the "0" flashe really fast, they you turn the key OFF. You turn the key back on and there is nothing on the display. I pressed the right button and nothing happened and it would not start, so I pressed the left button and it went to "1" and started right up. Guess there must be different ways of getting it back. I held my breath till it started, I just didn't want to do something I was going to regret. Anyone thinking about doing the DP with NO START...It works!!
1999 F350 dually
Jul 24, 2017 11:53 AM
deck60
Jul 11, 2017 05:12 PM
Outsider HD
New Member Introductions
Jan 17, 2017 10:44 AM
Tburns96PSD
Sep 18, 2016 04:29 PM
dpkilleen
Feb 18, 2010 02:51 PM
