Fuses To Pull To Kill Engine?
Here is how I did mine:
Oh, I cut a small notch out on the Fuse box cover to allow the wires to pass.
Ha, you just mentioned just about anywhere in this what to be a great country. With the exception of maybe Idaho and Alaska there is nowhere safe from the cockroaches.
You will need:
-5 male crimp-on blade connectors
-7 insulated female crimp-on blade connectors
-1 toggle switch (choose your style)
-At least 8 feet of 18 guage wire, or more depending on where you plan on mounting your toggle switch.
-1 small zip tie
-Cut 4 pieces of wire 12 inches long, crimp a male blade connector and a female blade connector on each end of the 4 wires.
-Locate the numbers on the relay near the blades, connect the 4 wires to the 30,87,87a,85 terminals.
-Attach the other ends of the 4 wires to the corresponding blade receptacles in the fuse box, where relay 303 was originally.
-Locate your secret toggle switch location, cut a wire long enough to reach from the toggle switch to the relay, crimp a female blade connector on each end of the wire.
-Attach one end of the wire to the toggle switch and the other end to terminal 86 on the relay.
-Cut another piece of wire long enough to go from the fuse box to the toggle switch, crimp a male blade connector on one end of the wire and a female connector on the other end.
-Attach one end to the toggle switch and the other end to the remaining open blade receptacle that blade 86 would plug into on the fuse panel.
-Carefully route the five wires toward the right of the fuse box and reinstall the fuse box cover, the fuse box cover may need to be notched to ensure the wires are not pinched when latched.
-Zip tie the relay to a desired location.
-Test
The first pic is a small version that was made to test with, you should get the idea though. These instructions were made very detailed so anyone could attempt this Mod no matter what their electrical skills may be. Hopefully this helps you guys! Good Luck!
Like I said, I DIDN'T write them but they seemed really great to go by. I see yours must have been grounded to the frame rather than running another wire back to the #86 terminal? Just noticed the differences...Thanks for your excellent pics..Dave
