08 rear diff cover
Old May 21, 2008 | 02:29 PM
C350CREW's Avatar
C350CREW
08 rear diff cover
did a search, but still not sure, i have a 95 350 dually, will this cover fit??
under one search it said it would fit the sterling 10.25-10.5?? did that mean single wheel?
if not, anyone know a source for a reasonbly priced cover???????
what weight oil? and how much?
any input on the royal purple? worth the money?
thanks in advance!!!
Old May 21, 2008 | 02:36 PM
Neal 97 250's Avatar
Neal 97 250
It will fit the dually's also. Same axle different length. I did Royal purple just a preference though. I( can't remember the weight right off the top of my head. 85/??? sounds familiar.
Old May 21, 2008 | 02:39 PM
93f1505.0L's Avatar
93f1505.0L
I think its 75w 140. I used moible syn. You need to use syn. and add friction modifier if you have a limted slip.
Old May 21, 2008 | 02:41 PM
93f1505.0L's Avatar
93f1505.0L
Oh and Powerstrokeshop.com is where I got mine ithnk it was 40 or so shiped.
Old May 21, 2008 | 07:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
75w-140 Synthetic is what my service manual calls for, and what I use. It holds less than a gallon....but I can't remember exactly how much.
You do not need friction modifier with any modern synthetic. Your limited slip will function better without it.
Old May 22, 2008 | 08:40 AM
C350CREW's Avatar
C350CREW
dont these covers need longer bolts?? couldnt find the post again but read yesterday that someone even found some stainless bolts?? what lenght and size??
thanks again for the help
Old May 22, 2008 | 08:58 AM
Neal 97 250
I believe they need to be 1-1/4" long IIRC.
Old May 22, 2008 | 09:00 AM
tjbeggs's Avatar
tjbeggs
Yep 1/4-20 thread at least 1.25 long. I found 1.5 long stainless and they worked without trimming them down.
Old May 22, 2008 | 10:22 AM
Joe_D's Avatar
Joe_D
I put mine on when I had the gears changed from 4:10 to 3:55. It looks great!
Old May 22, 2008 | 11:47 AM
BlueMule's Avatar
BlueMule
1/4-20 seems awful small, I thought they were 5/16-18
Old May 22, 2008 | 12:17 PM
Neal 97 250
I believe tim is right 1/4-20
Old May 22, 2008 | 01:15 PM
tjbeggs's Avatar
tjbeggs
See next post
Old May 22, 2008 | 01:21 PM
tjbeggs's Avatar
tjbeggs
OOPS!! I was wrong! they are 5/16-18 not 1/4-20! went back to my thread when I installed. I Lied!!
THE BOLTS ARE 5/16-18
Old May 22, 2008 | 02:06 PM
C350CREW's Avatar
C350CREW
how good does the surface look? anybody tried to polish cover?? then you could have a clear powder coat put on and should look outstanding.
Old May 22, 2008 | 02:10 PM
93f1505.0L's Avatar
93f1505.0L
I think it would be really hard to polish. It would need a lot a sanding and there are too many tight spots. It looks great the way it is though.
