Merc pistons for a Merc crank
Old 10-04-2004, 07:59 AM
True2Blue's Avatar
True2Blue
True2Blue is offline
Hello all,
I recently acquired a merc crank for my 8BA flathead and I'm looking for the truth to piston requirements. In reading posts to this and other forums it seems more of an opinion than fact that you must run merc pistons with a merc crank. Does anyone out there know the truth? Just being an average Joe resurrecting a flathead for my '53 F100 I'm looking for the most bang out of my buck.
Thanks in advance for your advice and knowledge - Bill
Old 10-04-2004, 07:01 PM
kotzy's Avatar
kotzy
kotzy is offline
Since the Mercury crank has a longer stroke the piston has to have the wrist pins set
closer to the pistons top or guess what they hit the head.
Old 10-06-2004, 05:33 PM
312's Avatar
312
312 is offline
ill back that up.
Old 10-06-2004, 06:09 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
The Ford and Merc Rods are the same the difference in the lenght of the stroke is made up by the rist pin placement as stated above.
If you try to use the ford piston with the merc crank its gonna get ugly quick. If you try to use merc piston with a for crank you get abot 2:1 compression
Old 10-14-2004, 03:24 PM
True2Blue's Avatar
True2Blue
Many thanks for all your advice. Looks like I'llhave to keep my eyes open for a decent set of Merc slugs.
Bill
Old 10-28-2004, 08:30 AM
sosotwo's Avatar
sosotwo
sosotwo is offline
I think I have a set of pistons for you 30 thou over sized
they are just about new
Old 10-28-2004, 03:47 PM
True2Blue's Avatar
True2Blue
Thanks soso one!! Members like you make this site a restorer's dream. Now if I can just figure out how to contact you. Should be able to repond to you via email shortly.
Thanks - Bill
Old 11-07-2004, 04:48 PM
green53's Avatar
green53
green53 is offline
merc pistons
True2blue, I had a merc crank and pistons put into my '51 8BA. The whole bottem end and flywheel should be balanced as well.[IMG]flatheadpics0010[/IMG]
Tienmac
24
06-07-2016 08:29 PM
canadianf1pilot
New Member Introductions
09-08-2015 12:07 PM
r_reed
10-21-2012 10:29 PM
FordmanShane
06-23-2012 11:41 PM
e-tek
41
04-25-2010 10:50 PM
Quick Reply: Merc pistons for a Merc crank
