IDM testing
Old May 21, 2008 | 12:51 PM
whiteywhip's Avatar
whiteywhip
IDM testing
is there anyway to test the idm when its out of the truck or can it be tested while in the truck or is there some place i can bring it to be tested??
Old May 22, 2008 | 06:38 AM
F350-6's Avatar
F350-6
Nothing I know of, but I'll bump it back to the top.
Old May 22, 2008 | 10:27 AM
PaysonPSD's Avatar
PaysonPSD
Here's another bump. Someone should have an answer.
Old May 22, 2008 | 10:15 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I'm not aware of any break out box type tester for an IDM. The only driveway test I can think of is to swap it out with another one.
Old May 22, 2008 | 10:18 PM
dustan52's Avatar
dustan52
What are you wanting to test it for?
Is the truck running funny?
Old May 24, 2008 | 09:26 PM
whiteywhip's Avatar
whiteywhip
yes real bad....if you read my engine service lite on....then part 2...then part 2 again you will see the problems ive been going through
Old May 25, 2008 | 01:43 AM
dustan52's Avatar
dustan52
did you start a part 2 of this thread? If not i don't see a part two, but this will bump you back up...
Old May 25, 2008 | 05:58 AM
JLDickmon's Avatar
JLDickmon
I've been down this road in the last couple of weeks; once on my own roach, and again on a customers'...
the only on-truck test for the IDM is ohm testing the high & low sides of the injector circuits (key OFF!)
now that's been said, lemme go find the other thread and I'll see if I can help more...
-edit-
Dood, I must be blind, or your thread is lost to the archival gnomes...
got a linkback?
Old May 25, 2008 | 06:29 AM
whiteywhip's Avatar
whiteywhip
thank you...i am stumped on this
