IDM testing
May 21, 2008 | 12:51 PM
IDM testing
is there anyway to test the idm when its out of the truck or can it be tested while in the truck or is there some place i can bring it to be tested??
May 22, 2008 | 06:38 AM
Nothing I know of, but I'll bump it back to the top.
May 22, 2008 | 10:27 AM
Here's another bump. Someone should have an answer.
May 22, 2008 | 10:15 PM
I'm not aware of any break out box type tester for an IDM. The only driveway test I can think of is to swap it out with another one.
May 22, 2008 | 10:18 PM
Quote:
Originally Posted by
whiteywhip
What are you wanting to test it for?
Is the truck running funny?
May 24, 2008 | 09:26 PM
dustan52
yes real bad....if you read my engine service lite on....then part 2...then part 2 again you will see the problems ive been going through
May 25, 2008 | 01:43 AM
whiteywhip
did you start a part 2 of this thread? If not i don't see a part two, but this will bump you back up...
May 25, 2008 | 05:58 AM
I've been down this road in the last couple of weeks; once on my own roach, and again on a customers'...
the only on-truck test for the IDM is ohm testing the high & low sides of the injector circuits (key OFF! )
now that's been said, lemme go find the other thread and I'll see if I can help more...
-edit-
Dood, I must be blind, or your thread is lost to the archival gnomes...
got a linkback?
May 25, 2008 | 06:29 AM
thank you...i am stumped on this
