Floorpans
Old May 21, 2008 | 01:50 AM
simonzelotes's Avatar
simonzelotes
Floorpans
Are replacements available for a '54?...I only need a small section on the drivers side...What about riveting them on instead of welding them on?..
Old May 21, 2008 | 07:21 AM
pinheads52's Avatar
pinheads52
They are available through LMC truck, and no to pop rivets thats a bad idea
Old May 21, 2008 | 07:43 AM
cmoritz's Avatar
cmoritz
Last time I checked, two different type's were available, the "black"
zinc coated, and the unfinished type ( no coating). I think the unfinished was actually a bit thicker metal, closer to the stock floor pan, and a bit more forgiving to weld ..due to the thickness, and the piece I would use if you can still get it.Shop around, don't be in a hurry, then make your choice.Good Luck!
Old May 21, 2008 | 08:35 AM
bobj49f2's Avatar
bobj49f2
Yeah, welding is the only way I'd do it. You could also check out panel adhesive, some members have used it to patch in body and door panels. I prefer welding, I'm kind of old fashioned and don't get into new techniques to easily.
Old May 21, 2008 | 11:31 AM
WALFORD'S 56's Avatar
WALFORD'S 56
If you are not welding the patch--then cut new panel as close as possible and use the new adhesives out now,or drill a hole or 3-4 and screw a few screws in it--till you can get it to a body-shop or someone that welds and have them weld it in.
Just make sure your carpet or rubber mat,etc and seat are easy to take out,or out already--don't need any fires!!! Adhesives work good--but welding looks nicer from the bottom. Bill
