Sponsored by: Auxito
Cams and Heads
Old May 20, 2008 | 08:55 PM
Dubs99's Avatar
Dubs99
Cams and Heads
I am looking at building up the top end of my motor, I am curious as to everyones input as to what combo to use. My motor is stock 4.6L/281 SOHC 2V
Old May 20, 2008 | 09:27 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A good cam (not sure whats out there as I've never looked) and some work to the heads (port & polish & valve job) would probably wake the engine up dramatically. Now, if you could find an aftermarket intake...that would probably make it a whole 'nother animal!
Old May 20, 2008 | 11:57 PM
Club Wagon's Avatar
Club Wagon
Better to try a pair of "good" cams.
Originally Posted by ATC Crazy
A good cam....that would probably make it a whole 'nother animal!
SOHC may mean Single OverHead Cam, but its 1 cam per head on a V8.
Try to figure out ahead of time if you'll want to remove the cab for access to R&R cylinder heads, as some FTE members have suggested.
Old May 21, 2008 | 07:06 PM
Dubs99's Avatar
Dubs99
Smile
Thanks for the tips, I knew that my truck has two cams
Old May 21, 2008 | 09:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, I know
Old May 21, 2008 | 10:54 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Id just pull the engine, its not that hard....
Old May 22, 2008 | 02:49 AM
Club Wagon's Avatar
Club Wagon
Good for you. Now there's less chance anybody might be confused.
Yes, I know
The singular connotations of "A good cam" & SOHC could be misleading.
You seem very experienced w/these pickups. What do you think of some member's seemingly preposterous claims that removing the cab is the expedient way to do head gaskets?
Old May 22, 2008 | 05:10 AM
phil6608's Avatar
phil6608
Iv changed heads over 3 times. And the motor comes out every time!
(Opening poster)
Ported heads and a good set of cams.
I recommend custom ground cams from Comp Cams.
Old May 22, 2008 | 08:15 AM
BURNSTOUGHFORD
You dont need to remove the cab or even unbolt it or anything, this engine comes out easily... only thing different from an normal engine pull is that the intake MUST come off.... i pulled my 4.6l with it on and dented up my fire wall a bit, but i put my 5.4l in without the intake without a hitch.... droped right in "literily" (lol long story)....
Old May 22, 2008 | 12:42 PM
Club Wagon's Avatar
Club Wagon
"What do you think of some member's seemingly preposterous claims that removing the cab is the expedient way to do head gaskets?"
So can we lay this extremely dubious procedure to rest once & for all? Or does anyone want to post on it's merits one more time?
Old May 22, 2008 | 12:58 PM
bowdog's Avatar
bowdog
I dynamite mine out.....two sticks of dynamite under the motor and it pops right out. Only work is placing the sticks and a lite.
Boom!!! Its out.
So all the other ideas are to much work.
Now get to work and put it to rest!!!!
Old May 22, 2008 | 05:02 PM
BURNSTOUGHFORD
Im not sure if your being sarcastic or not, but i know for a fact since i did my own engine swap...
Old May 22, 2008 | 10:29 PM
Club Wagon's Avatar
Club Wagon
https://www.ford-trucks.com/forums/7...b-removal.html
Old May 22, 2008 | 10:42 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Im not sure if your being sarcastic or not...
Club Wagon and I got into it a little bit about that in another thread. No offense at all Club...but the way you word your posts makes it very hard to comprehend. Use some smilies or something to express your feelings/thoughts...
As far as the cab removal...I don't see why you would need to remove the cab to pull the engine? You shouldn't even have to pull the front clip off. But, I have never pulled one of these engines (and I damn sure don't want to!).
Old May 23, 2008 | 02:23 AM
phil6608's Avatar
phil6608
It's no big deal to pull the motor.
Just remove the hood/intake and radiator and it comes right out...lol
