waterpump leak?
Old May 20, 2008 | 04:30 PM
ponch37300's Avatar
ponch37300
waterpump leak?
I noticed a leak coming from where the lower radiator hose leaves the water pump. Looks like there is a flange that is bolted to the pump that the hose goes onto. The leak seems to be coming from where the flange meets the water pump. Where is the best place to get a new pump? Or do i need just the flange? Also any tips on fixing this? Thanks
Old May 20, 2008 | 04:52 PM
rbaker6336's Avatar
rbaker6336
there is an o-ring inside the flange ,probly needs replacing
Old May 20, 2008 | 05:14 PM
ponch37300's Avatar
ponch37300
Thanks rbaker... Do i just get this oring from the local parts store or is this a dealer only part? I have to drain the whole system to do this right? Thanks again, hopefully that is all it is and i don't need to replace the pump.
Old May 20, 2008 | 05:23 PM
rbaker6336's Avatar
rbaker6336
I think is a dealer item
unless you need to flush system,just drain radiator in a clean container the strain and reuse coolant
Old May 20, 2008 | 08:09 PM
midnight1967's Avatar
midnight1967
Mine was leaking in the same place not to long ago, i had 115,000 on it so i thought since i got to drain it anyway did a new water pump, thermostat and new fluid so i dont have to worry about it for at least another hundred thousand just a piece of ming for myself.
Old May 20, 2008 | 10:13 PM
ponch37300's Avatar
ponch37300
midnight...Where did you get your pump and how hard of a job was it to change? Where did you get that oring? Thanks
Old May 20, 2008 | 10:33 PM
grahcwp's Avatar
grahcwp
I'm not midnight, but I recently did my water pump 99 F350psd. $145 new Advance Auto, other cheaper ones out there. 3 hours job done right, no shortcuts. Large wrench needed to remove fan clutch or pull shroud with whole assembly. I think my water pump was original (240,000 Mi). I had previously replaced said o ring which is about a 40 minute job. Watch out on after market thermostat as not all have the proper gasket program. Dealer thermo safest way to go. O ring available at dealer and it was less than 10 maybe 5 bucks.
Old May 20, 2008 | 10:52 PM
PaysonPSD's Avatar
PaysonPSD
Ponch,
You should go with a 203° thermostat and billet housing first. If you still have a leak you can put these on the new water pump.
Thermostat HERE Billet Housing HERE
JMHO
Old May 20, 2008 | 10:57 PM
grahcwp's Avatar
grahcwp
Your leak was from the lower connection, right? The thermostat issue was if you replaced the water pump.
Old May 20, 2008 | 11:36 PM
PaysonPSD's Avatar
PaysonPSD
My bad Ponch. You were talking about the lower pipe. Trying to watch "Deadliest Catch" and read at the same time.
Here are part numbers for both O-rings:
THERMOSTAT Housing O-ring # F4TZ-8255-A
LOWER PIPE O-ring # F81Z-8255-AA
Keep in mind the 203 and billet housing if you do a new pump.
Old May 21, 2008 | 08:07 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I used a standard o-ring from a Harbour Freight o-ring kit, whole kit was only ten bucks, and it sealed better than the factory style square cut o-ring. And yes you can buy the o-ring at any good parts store, I bought one in town and returned it because I like the way my o-ring fit better. Good luck, it really is an easy fix as long as one of the bolt heads don't round off like it did for me.
Old May 21, 2008 | 09:17 PM
midnight1967
sorry i didnt answer sooner but i had the stealership do it since i was working alot of ot and couldnt do it, but i see some of the other guys here have the part numbers so you should be alright ...good luck.
Shake-N-Bake
Mar 9, 2010 11:59 PM
DND58
Nov 23, 2009 08:01 PM
03 Maz B23
1983 - 2012 Ranger & B-Series
Aug 4, 2008 05:05 PM
BlackJeep
Apr 30, 2008 06:06 AM
Rick2001
Jan 22, 2008 10:16 PM
