Trans Rebuild?
Old May 24, 2008 | 09:30 PM
Stroked Out!'s Avatar
Stroked Out!
Trans Rebuild?
I Pull Alot Of Weight All Week Long And Im Very Sucpicious Of My Tranny Going Out On Me When I Need It To The Least,should I Just Get Rebuilt And Be Done Or Wait Until It Really Show Wear. It Hard Shifts Sometimes And Kicks When I Put It In Gear Mostly Reverse? Any Sugg. And Cost Of A Rebuild?
Old May 24, 2008 | 11:19 PM
doubledee715's Avatar
doubledee715
I suggest you have it flushed and replace the external filter and see if that helps. I believe a suncoast rebuild is somewhere around 2k.
Old May 25, 2008 | 02:46 AM
cartmanea's Avatar
cartmanea
Agree, have it flushed or do a fluid change yourself. Also, if its shifting hard, try disconnecting the battery to clear the memory. Then, reconnect and do one light takeoff through all gears, then one hard takeoff through all gears to let the tranny 'relearn' its shift patterns. What year truck and what tranny do you have? I know this is mostly for the TorqShift, but would probably help for earlier autos too.
Old May 25, 2008 | 06:46 AM
m350's Avatar
m350
I recently did the tranny filter, SP MC fluid and the remote trans filter,,,had 33k miles on my 06' F-350 6.0 TS,,the truck has plowed snow, since I got it,,I have 3 different trailers I pull,,,and I dont baby her either,,,the Pan was clean,,no residue,,(as my buddy put it) saying it looks real Good in there.
