pump problems
Old May 19, 2008 | 09:53 PM
bigrigg1's Avatar
bigrigg1
pump problems
ok all my FTE friends, i took the family out for the 1st camping trip of the season and the weather was great BUT not all was well friday night the wife was putting the kids to bed and heard a humming noise my water pump was running and wouldnt shut off when i turned on the cold water faucets on all i got was hot water out of both any ideas on what my problem might be
camper 2001 nomad 249LT not sure about what kind of pump i havent taken it out yet
thanks
Old May 20, 2008 | 06:17 AM
Toyman's Avatar
Toyman
That's a tuffy. I would first look at all the connections, make sure you don't have a leak. Does the water only come out hot at one faucet or kitchen and bathroom. If it is isolated to one faucet that is most likely the problem, it would have an internal crack causing the hot to come out of both sides. Was it in for service since you last used it? Tell us more about the trailer, make model, etc.
Toyman
Old May 20, 2008 | 06:51 AM
dertdrag's Avatar
dertdrag
Had that happen to me before, spring,first time out and all.
Was the water heater bypass valve. Valves were all open letting the hot water go wherever it wanted.
Old May 21, 2008 | 01:50 PM
mel2000f150's Avatar
mel2000f150
I agree with dertdrag, check the water heater bypass valve/s.
As for the pump running all the time, there must be a leak in the system
Old May 21, 2008 | 02:31 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
My first thought was also the h/w heater bypass valves in the wrong position.
as far as pump constantly running...a question...
When you winterized...did you use anti-freeze? and if so...did you winterize the city inlet via pushing the plunger?...and if so...did you happen to push that when the system was pressurized...if so...you may have popped the internal O-ring off the plunger and have a leak outside that you may not notice...turn on the pump and go look at the city inlet to see if water is leaking...that is just a thought on where to look...as it is a common problem if you push that plunger with pressure in the water lines to pop that O-ring...
Good luck,
joe.
Old May 21, 2008 | 02:55 PM
MarkMoore's Avatar
MarkMoore
I agree with others here - I think your valves are positioned worng. I have 2 on mine - one for the 'in' to the h2o heater and one for the 'out' to the rest of the TT.
As far as your pump, on our previous TT we had the same problem. I found that setiment had accumlated in an elbow between the pump and tank - it was enough to restrict flow to the point that the pump wasn't getting enough water to kick off.
Old May 21, 2008 | 05:39 PM
bpounds's Avatar
bpounds
I don't have a clue on the hot water thing.
But as far as the pump humming, mine will do that until it is primed. I have to crack a faucet so a little water has someplace to go before it will build and hold pressure.
We have forgotten to turn the pump off many times before driving, and for some reason the pump will lose it's prime and then when we get in the coach it will be running and humming. Usually it's after a potty break and the wife forgets to turn the pump off. Something to try anyway.
Bill
Old May 22, 2008 | 09:48 PM
bigrigg1's Avatar
bigrigg1
thanks for all the help guys, i am going to try and get it figured out this weekend and the suggestions are a great place to start
bulla
38
Jul 16, 2019 03:02 PM
djmechanic
Jul 12, 2016 12:31 AM
Berardini2121
1978 - 1996 Big Bronco
Apr 22, 2016 11:49 PM
fdude64
22
Aug 6, 2015 06:34 PM
goose_ss4
Sep 15, 2013 07:11 PM
