Does this sound right?????
Old May 19, 2008 | 07:58 PM
rhodeisland350's Avatar
rhodeisland350
I brought my truck into the dealer last week for an oil leak around the bell housing. They couldn't pinpoint the leak so they put the UV dye into it and told me to drive it 500 miles or so and bring it back.
I brought it back the other day and i when i called to get an update on it today the guy told me it was the headgaskets and they were going to be replaced. Does that seem right? I'm looking to you guys for help b/c i'm a relative newbie to 6.0's but i'm in freakmode and the dealership i brought it to is supposedly legit, i just wanna make sure.
I bought in Feb w/ 41k miles on it and it now has 47k on it. The oasis report for it was clean prior to me buying it.
Thanks!!
Old May 19, 2008 | 08:51 PM
UGA33's Avatar
UGA33
Bump^^. Not the best diagnoser of problems on here, but i havent read in the 2 yrs i have been on here that people were leaking oil and the headgaskets turned out to be the culprit. Techs help me out here! But if the dealers are going to fiddle around with them, see if they will put you some ARP studs on there if thats the route they are going to take
Old May 19, 2008 | 09:56 PM
adamsre's Avatar
adamsre
Yep, definately buy some ARP studs and have them installed at the same time. Best $400 you can spend on your truck.
Old May 20, 2008 | 09:53 AM
rhodeisland350
I called back this morning and spoke with one of the service writers. Evidently they traced my oil leak w/ the dye and found the origin of the leak and also found a coolant leak in the same area, that is the reason for the headgasket replacement. I have asked about replacing the bolts w/ ARP studs when they put everything back together and they are going to let me know if they will do it. I have my fingers crossed!
Old May 20, 2008 | 04:00 PM
UGA33's Avatar
UGA33
That would be awesome if they can pull that off for ya! Good Luck!!
amstel78
Mar 15, 2011 09:50 AM
mattebury
6.4L Power Stroke Diesel
33
Apr 10, 2009 07:50 PM
jdemaris
30
Aug 9, 2007 12:40 AM
chrono4
Offroad & 4x4
36
Aug 12, 2006 09:39 PM
Vermont250
Dec 4, 2005 06:33 PM
