292 engine mounts
Old Mar 31, 2001 | 07:12 PM
Nathan's Avatar
Nathan
292 engine mounts
Has anyone bought new rubber mounts for their 292 truck motors? I ordered some before and got the wrong ones. Just wondering where to get the right ones. My truck is a 64 F100.
Thanks
Nathan
Old Apr 4, 2001 | 11:36 PM
flatblack's Avatar
flatblack
292 engine mounts
I just bought motor mounts for my
57 truck. I got front and rear, upper and lower.
I have a 292, which mounts at the front and at the
back on the bell housing, I think yours is the same.
At any rate the rear mounts were right, but the front
lower mounts had a hole that is to small for the bolt.
the upper front mounts were fine. I bought them form a
place called Sacramento Vintage Ford. I also found that
some parts houses can get them if you have the old ones.
Sac Vintage can be reached at 1-888-ford-100. good luck
Old Apr 5, 2001 | 06:57 AM
Nathan's Avatar
Nathan
292 engine mounts
Thanks FB
Nathan
Old May 5, 2001 | 11:02 PM
darkman's Avatar
darkman
292 engine mounts
Flatback,
Someone replaced my rear/trans mount bolts and the bushing was missing. I have ordered and recieved new bushings. I'm assuming they are correct as I have nothing to compare them to. What I need to know is the throughbolt a standard bolt or does it have a unusual shank of non standard size to fit the bushing?
Thanks Charles
Old May 9, 2001 | 08:35 AM
darkman's Avatar
darkman
292 engine mounts
Fomoko1
20
Mar 27, 2007 09:39 AM
Nathan
Jul 18, 2001 06:36 AM
Nathan
May 4, 2001 09:40 PM
Nathan
Sep 25, 2000 01:33 PM
Nathan
Jun 5, 2000 07:59 AM
