Dive bomber turbo?
Old May 19, 2008 | 12:18 PM
Headrope's Avatar
Headrope
Dive bomber turbo?
Does a stock '05 6.0 have an auxiliary turbo cooling fan or auxiliary turbo boost booster or something?
While pulling trailer over some mountain passes this weekend I encountered a new noise. In addition to the usual turbo sound it sounded like a German dive bomber from a World War II film would spool up under load. After it did whatever it did the dive bomber sound would bleed off - similar to the way a regular turbo does when you lift of the pedal a little - without me lifting off the pedal. It sounded like it was supposed to happen but I don't know what it was ... if that makes any sense.
I've pulled the same trailer/weight over the same passes before and not heard the sound, though it was much hotter and there was a stronger headwind this time so there was likely more of a load on the motor.
Do I have a Messerschmitt under my hood or what?
Old May 19, 2008 | 12:33 PM
powerstroker27's Avatar
powerstroker27
Its prob just the fan kicking in. Like u said is was a lot hotter and u were driving against a head wind, hotter air temp + engine under a heavier load = hotter engine temps and subsequently the fan to kick on. So u shouldn't have to worry......there arn't ***** hiding under ur hood lol
Old May 19, 2008 | 02:10 PM
mnmwhit's Avatar
mnmwhit
yep clutch fan can get noisey
Old May 19, 2008 | 05:49 PM
Headrope's Avatar
Headrope
Alrighty then. I won't worry about it.
Thanks for the replies.
Old May 19, 2008 | 10:46 PM
jmaskew's Avatar
jmaskew
A dive bomber scream is more like a whistle than a fan sound. Are you loosing coolant? Are there any white spots around the degauss bottle?
Old May 20, 2008 | 12:12 AM
cartmanea's Avatar
cartmanea
Its the cooling fan.
rbig1
May 27, 2016 02:40 PM
mcmahonbj
1947 and Older Ford Trucks
26
Sep 26, 2015 03:00 PM
Mark_in_co
Aug 22, 2015 10:35 PM
DonkeeXotee
New Member Introductions
Jan 14, 2014 10:35 PM
Blue Bomber
Tennessee Chapter
Jul 14, 2008 09:24 AM
