trans help
Old May 18, 2008 | 09:03 PM
keithdcornett's Avatar
keithdcornett
trans help
i have about 2000 miles on a rebuilt trans hd torkconvt with a banks transcomand {never did work verry well}i added a bullydog trans upgrade on topof an it . dos ok still slips sometimes my quistion is will coons trans kit help or witch do i need to take out or both
Old May 18, 2008 | 09:22 PM
Todd525's Avatar
Todd525
is the tran slipping or is the the TC?? I was unaware that you could stack tranny command modules. This is one thing I will never use. All these do is increase line pressure by tricking your system. I have never beeen a fan of that. I haul 22k ALL the time, well, three times a week or so, and have NEVER put a module in my turck. I did have to replace the tc at a little over 100k miles, now have over 165k on it and never misses a beat.
Old May 19, 2008 | 08:29 PM
keithdcornett
well i have 300k 4th trans the banks has ben in 200k an dont thank its working the bullydog works better or seams to harder shifting .but under hard axcerlation somtimes it seams to shudder in 3ed i think thats when the tc locks or not ?
Old May 19, 2008 | 08:34 PM
keithdcornett
96f250 e40d 3dn guted cat tsperformanse 6637 filter 14.7mod
Old May 19, 2008 | 09:27 PM
Todd525's Avatar
Todd525
I believe that the converters in our trucks are multi stage. They lockup in percentage if i remember right. If you see a lockup at about 40 mph into od with 4.10 gear ratios, and you go to accelerate SLIGHTLY, do you see the rpms slide up or do they stay the same? If they slide, your TC is TOAST. If they dont move much while acelerating SLIGHTLY, you have other problems. Do you still have the worthless stock tranny cooler? This is the main problem for the stock tranny to go south.
Old May 19, 2008 | 09:34 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i reccomend removing both kits you have and see what the truck feels like bone stock.
from there you can decide what is going on, you should always have a solid trans before modding it, adding the kits can mask potentialy catastrophic failures. the 3rd gear shudder you feel could be the converter clutch engaging. i am not happy with the transcommand programming, take that out first and see what it does. but you should really start from scratch and see if you still have the issues.
odds are you have a rebuild issue and need to get it fixed asap before your warrenty runs out. what kind of heavy duty converter went in it? who did the rebuild? what components did they replace? any upgrades? lots of questions to be answered before you throw anymore parts at it.
Old May 19, 2008 | 10:54 PM
MADVAN's Avatar
MADVAN
X2
Remove the command and test. If you have the bypass plug just install it.
Pattern is 1,2,3,tc lock,4th tc lock. Light/med throttle.
The TC lock in the E4 is on or off. The 4R has PWM locking. The PWM is for a softer lock.
Bill
Old May 20, 2008 | 05:06 PM
keithdcornett
Thumbs up
thanks for the advice .i have to pull to sumterville fl.sunday about 580mi.so i will take friday or saturday see wot hapens thanks
Old May 21, 2008 | 03:31 AM
IDMooseMan's Avatar
IDMooseMan
Let us know your results.
Old May 21, 2008 | 07:05 AM
MADVAN's Avatar
MADVAN
If the reman unit has a pump mod it will not work well
with the transcommand.
Bill
