Transmission cooler lines direction of flow.
I am not sure which transmission you have, so I will list the lines for the 4R70 and the
4R100. Hope this helps.
The return line to the 4R70W is the top line on the transmission.
so the top line on the transmission is the cool line IN from the rad.
bottom line of transmission is hot line OUT to the rad.
4R100 Front (Forward) line on the transmission is the OUT line (Hot) to the rad.
The Rear line on the transmission is the IN line (Cool) from the rad.
I have two expeditions. One is a 1999 the other is a 2004. The 1999 has a 4R100 transmission with an auxillary cooler. The 2004 has a 4R70 and Top line on the radiator is the return line (Cool) to the transmission. The Bottom line on the radiator is the In Line (Hot) from the transmission.
(Sorry about the incomplete previous post, hit the wrong key)
gary's1950F1
12-12-2016 10:53 PM
