Back Up Lights
Old May 21, 2008 | 12:04 AM
gusso's Avatar
gusso
Old f1
You may be on to something here. Trouble is, I`m not familiar with this item.
Any one know where can they be purchased? And what they are called? I`ll
google license plate retractor and see what happens. Thanks. Sound like a great idea.
Gary
Old May 21, 2008 | 08:24 AM
56panelford's Avatar
56panelford
I like Old F1 idea but was wondering if that was a stainless steel bumper you had or a crome one, you could cut slots and mount led's that would probably be not too noticable.
Old May 21, 2008 | 08:56 AM
AXracer's Avatar
AXracer
I would first look at the function/reason for having back up lights in making a buying decision. Primary function: to provide illumination behind the vehicle when backing up. Secondary function: warning to other drivers that you are/about to back up. No function: I've added a doodadd just to say I did.
Too small a light will not provide any useful illumination.
Too hidden a light will not be seen by other drivers, they will not be looking for lights installed under the truck.
Both above cases together = doodadd IMHO why bother?
The small oval bullet shaped driving lights mounted on the bottom of the frame rails would provide ample light, and could be painted frame color to nearly disappear.
My panel has a rolled pan so I could not easily use the driving lights, and since I will be towing with it I wanted plenty of illumination for backing up as well as hitching the trailer and warning others due to limited rear visibility in a panel, I decided to go with 2 3/4" round ultrabright LED lamps minimally frenched into the rolled pan.
I use SUPER BRIGHT LEDS home for my LED needs.
Old May 21, 2008 | 09:13 AM
Old F1's Avatar
Old F1
It would take much engineering, (just because you can if you want to), but Plan “c” or is it “d” could a LINEAR ACTUATOR (electric worm screw) that is used to raise trunk lids.
Old May 21, 2008 | 10:09 AM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
How about a roof-mounted spotlight, just face it backwards, when you want to see behind you??
Do I smell a rat-rod??
R
Old May 21, 2008 | 10:55 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
There's plenty of small electric and/or vacuum actuators that could probably be adapted to work. I think that basically what the retractable license plate mechanisms are.
I think AX may be onto something here with a small driving light, painted frame color and mounted forward of the rear of the truck a little bit, maybe next to the spring hangers. To me that sounds like the simplest solution. There's tons of small lights available from the street rod and custom motorcyle markets
Bobby
Old May 21, 2008 | 06:15 PM
angus's Avatar
angus
There's those little halogen sealed-beam units like you see on track lighting, with various wattages at 12V. The problem is finding a weatherproof housing for them, but maybe some of the mini driving lights use that style of lamp, and used as is or be frenched into a bumper or roll pan.
Old May 21, 2008 | 07:09 PM
Kusto's Avatar
Kusto
Originally Posted by gusso
Bobby ,
I like Kusto`s idea also. What I`m toying with is some sort of light that, with a press of a button, will gear down 90 degrees, and light up. I`m sure they are made. Its just a matter of finding a source. Anyway, Bobby, Keep those icy pops close by. Oh, and by the way,
copy anything. I consider it a great compliment.
Thanks for the input.
Gary
Hey guy's I have attached some photos of the lights and the thread posted by another member( Ford Truck Enthusiasts Forums - View Profile: Bear Hunter )in the Superduty Diesel Forum that I am in as well. Have a look at the thread and you will find details on the types of lights that are available. I was thinking of getting a set for MY PSD and never really thought a lot about BU lights for my 48 but I agree that it won't hurt to have a set and now will just get two sets at the same time.
Here is the link. https://www.ford-trucks.com/forums/5...with-pics.html
Old May 21, 2008 | 07:41 PM
gusso's Avatar
gusso
Kusto
Awesome!!! Autozone Tomorrow-------
Thanks for info
Gary
Old May 21, 2008 | 07:58 PM
Kusto's Avatar
Kusto
Yeah, I think they're pretty sweet little lights and would certainly blind anyone behind you. On another note, if someone is walking behind you while you are backing up, the light would just vaporize them so you won't need you worry about scratching your paint.
gusso
Jan 21, 2009 12:49 PM
gusso
16
Jan 24, 2008 01:36 PM
gusso
Sep 11, 2007 12:59 PM
gusso
15
Aug 31, 2007 11:38 PM
gusso
21
Dec 24, 2006 05:57 PM
