hi help needed
Old May 18, 2008 | 04:24 PM
fordguy2006's Avatar
fordguy2006
Question hi help needed
could anyone tell me the difference between a flywheel and a flex plate ? thanks for your support
Old May 18, 2008 | 07:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A flywheel is heavy, stiff, and has a surface for a manual trans clutch to apply to. A flex plate is thin to allow it to flex when an automatic transmisson's torque converter expands.
Old May 18, 2008 | 07:52 PM
fordguy2006
thank you for the info mark . it's actually for a boat , and they use a coupling for the shaft to slide into so i think i'll go with a fly wheel . thanks again
