292 distributor parts
Old Nov 27, 2001 | 02:49 PM
57_F600's Avatar
57_F600
Post 292 distributor parts
hello,
i have a 292 in a 1957 F600. it has a vacum advance distributor. well, i changed the points and condenser in it. and also put a new cap on it. i put it all back together and turned it over. well when i turned it over it made a clicking noise in the distributor. i took the cap off and took the points back out and noticed that the flat linkage that went through the side of the distributor into that round vacume piece on the side with the spring inside, had pulled completely out and bent around the points. what i was wondering was if i could buy the round vacume piece with the spring inside with the little linkage and just replace that instead of the entire distributor? i can make the wires so they aren't any big deal.also why would the linkage have come out of there anyway. i noticed that the the linkage has a hole in the end and i think that it is held on with a couple snap rings. that is how thew part in the distributor is held on. what do you suggest i do to solve this problem?
thanks,
57_F600
Keep 'Em Crankin'
Old Nov 28, 2001 | 02:57 PM
rogerf100's Avatar
rogerf100
I replaced my vacuum advance with a new one from Sacramento Vintage Ford Parts. Check out their website at www.vintage-ford.com
rogerf100
Old Jan 3, 2002 | 06:08 PM
57_F600's Avatar
57_F600
hello,
thanks for your suggestion. i was able to find one at my local salvage yard. i had to search through an entire old seyferts chip van full of them to find but i got one. then they had the nerve to charge me $37.10 for it. oh well it runs good now. also almost got the cab interior clean up and ready to paint.
thanks,
57-F600
Keep 'Em Crankin'
Old Jan 3, 2002 | 09:44 PM
rogerf100's Avatar
rogerf100
51FordTN
20
Mar 18, 2015 06:53 PM
Myfreeford
Apr 3, 2013 09:50 PM
onewaymike
Jan 20, 2013 10:17 AM
himmelberg
18
Mar 5, 2004 06:24 PM
SOSRICKY
Jan 26, 2003 02:38 AM
