What size Y Block??
Old Sep 20, 2001 | 08:14 PM
Fatz's Avatar
Fatz
What size Y Block??
I just got a 1955 Ford short 18' school bus ( I just wanted the rebuilt motor ,body is now listed in classifieds for sale) and dont know how to tell the size? is it more than a 292 ? 312? 317? If it is any help there is a stock fan shroud, how do I tell thanks, Fatz
Old Dec 30, 2001 | 08:22 PM
GLPerry's Avatar
GLPerry
What size Y Block??
G. L. Perry
Huntington, IN 46750
My repair book lists only 239 or 265 (or is it 256?) for 55 trucks other than the bigger Lincoln type used in the bigger F-700's and 800's. 272's were used for next year and after that were 292's.
Old Jan 3, 2002 | 09:44 PM
rogerf100's Avatar
rogerf100
What size Y Block??
If you know it had the original engine, then find the vin plate and decode the engine type from that. There could be a lot of engine options since it is not a standard truck. Does it have the cross over exhaust pipe in front of the engine or the rams horn type exhaust manifolds? If you can check the drivers side of the block you can get a block casting number with 3 letters but unless you know the year it was made you still can't tell. You will need to find the date code that is hand stamped on the front of the block just in front of the valley pan. With these 2 pieces of info you can tell exactly what engine you have.
rogerf100
Old Jan 9, 2002 | 06:18 PM
darkman's Avatar
darkman
What size Y Block??
Fatz
Nov 25, 2001 01:37 PM
Fatz
Nov 17, 2001 07:51 PM
Fatz
Sep 30, 2001 08:19 PM
Fatz
Apr 17, 2001 06:03 AM
Fatz
Feb 28, 2001 10:45 PM
