Sponsored by: Real Truck
Removing stereo
Old May 18, 2008 | 10:50 AM
willtim6006's Avatar
willtim6006
Removing stereo
I have a 2000 F250 Lariat with a broken CD player.Does removal require a special tool?Is it worth repairing or should I buy an aftermarket unit?What fits?Thanks.
Old May 18, 2008 | 11:22 AM
jake00's Avatar
jake00
probably cheapest to get an aftermarket. as far as removal, a bent wire coat hanger in the 2 sets of holes on either side if the radio should do the trick
Old May 18, 2008 | 11:49 AM
rebelyell618's Avatar
rebelyell618
i would say aftermarket cd player or post on craigslist that you are looking for a factory replacment.
as for the tool a coat hanger bent in a "u" shape works but i reccomend going to walmart and buy the radio removal tool. like 4 bucks and it allows it to be a one person job since it already has the notches at the end that allow the factory radio to hold on to it instead of having to pull the radio out with a second person while you disengauage the factory radio with the tool.
Old May 19, 2008 | 11:04 AM
Beerstalker's Avatar
Beerstalker
These guys have you covered pretty well on removing the radio.
As far as replacing it goes, I would recommend aftermarket also, unless you live in a high crime area and do not want to add an alarm. Aftermarket stereos usually give you a lot more options for the same amount of money as the factory units. You can install a single DIN unit very easily with an install kit. They usually have a small pouch underneath that you can use to store a few CDs or something like that.
Otherwise you could fit a double DIN stereo with a very minor amount of trimming to your dash, and using an install kit from a late 90s Explorer. The trimming is so minor that you can actually install your factory stereo again afterward and not even know anything ever changed. I installed a Kenwood DDX-6019 in my 99 F250 and really liked it. If you want to give us some ideas of what kind of features you would like we could give you some recommendations. Off the top of my head I would suggest the Kenwood DPX302 or DPX502 if you want to stick with a more traditional CD player, or maybe step up to a DNX5120, DNX7120, or DNX8120 if you want to go all out with DVD player, navigation, bluetooth hands free, etc. Here's a couple links.
Kenwood DPX302 (dpx302) , In-Dash Head Units, Receivers, Double DIN (2 DIN Receivers) - Sonic Electronix
Kenwood DNX5120 (dnx5120) , In-Dash Head Units, Receivers, In-dash DVD Players (with monitor) - Sonic Electronix
Old May 19, 2008 | 04:24 PM
RckyMntnKng's Avatar
RckyMntnKng
I have the deck from my 01 lariat with tape and CD, as well as the keys to remove the old radio. The harness would hook right up. Its for sale (cheap) if you want it.
Old May 19, 2008 | 04:46 PM
biz4two's Avatar
biz4two
Arrow
You could always go look at eBay. I know they have them there...and you might be able to find an OEM 6CD changer as a replacement.
Good luck...
biz
srkr
Apr 7, 2017 08:10 AM
Traildust
Nov 15, 2016 08:23 AM
Restlesswildman
May 9, 2016 10:56 PM
OFF 59
13
May 31, 2012 10:22 AM
f350fixaliter
Nov 30, 2010 08:35 PM
