Remote Starters?
Old May 17, 2008 | 09:27 PM
VinceG1970's Avatar
VinceG1970
Question Remote Starters?
Recently bought an 07 F150 and I'm wondering if the Ready Remote series of remote starters will work or will there be limited functionality?
Old May 18, 2008 | 10:47 AM
D-mon's Avatar
D-mon
i am looking at a 07-08 f-150 and i would prolly get remote start so i was wondering the same thing
Old May 18, 2008 | 12:40 PM
Ryan50hrl's Avatar
Ryan50hrl
I like my ford 6 button unit...has an alarm built in....and works quite well......
Old May 19, 2008 | 01:15 AM
mattd17's Avatar
mattd17
ive always been a fan of aftermarket units.... i have, and love my crimestopper unit. i personally hate alarms, but love the features of remote starters/keyless entries..... i can even roll my windows up with the "trunk pop button". and, the aftermarket are really cheap to buy, and install yourself.
Old May 19, 2008 | 09:30 AM
Twinsdad98's Avatar
Twinsdad98
I personally like the Ford starters. I know too many people that have had issues with aftermarkets on the newer vehicles equipped with PATS. I have had my remote from Day 1. Almost 4 years and not a single problem. Like Matt, I hate the alarms, but like the features..
Old May 19, 2008 | 04:54 PM
mattd17's Avatar
mattd17
this brings up a good point.... many people have had problems with PATS.... but they are very simple to get around. if you get a good unit, then they dont require an extra key, but instead will program just like a spare key. ive used a few of these now, and they work great.
Old May 19, 2008 | 09:04 PM
Ryan50hrl's Avatar
Ryan50hrl
what have you all hooked up the extra accesory buttons to on your truck....i've got two extra buttons on my key fob that it seems like a shame to not use
Old May 19, 2008 | 09:30 PM
bridge's Avatar
bridge
Sick 'n Tired
While I like to go stock/ford add-on products when possible, when it comes to remote starters/alarms the aftermarket units have the best features. My UNGO (Clarion, but made by DEI) has extended range, aux channels, tells me the cabin temp of my truck and does everything the stock unit does. And it's just as easy or hard to install (are you a glass is half full or empty person?) as the Ford units. The installation of aftermarket units is the same as the one's Ford sells. When I bought and installed mine I used the Ford Remote Starter instructions to put it in and it was somewhat straight forward.
As far as extra channels, My Lariat doesn't have the sliding rear window or sunroof, but if it did that and the windows is what I would probably assign to the extra channels.
Old May 19, 2008 | 11:41 PM
mattd17's Avatar
mattd17
i assigned my trunk pop button to a window roll up module. so, just one press on it, and all 4 windows will roll up. pretty nice for those oh so sudden rain storms.
one more thing to think about if using aftermarket..... you will lose your ford features for "perimeter lighting", and the unlocking sequence (1 press-drivers door, 2 presses- all doors). to get around this, there are modules available that you solder a spare ford remote to, and then the aftermarket unit will send its signal through this module, and that will re-gain the ford features..... takes a little more time to install, but worth it IMO.
Old May 20, 2008 | 07:33 AM
bridge's Avatar
bridge
Sick 'n Tired
What is perimeter lighting? My unit had an option for "door priority" which allows the drivers door unlocking, followed by the rest. If I recall correctly I had to run a single wire to the GEM module behind the rear seat and tie into a wire after the module.
Old May 20, 2008 | 08:38 AM
mattd17's Avatar
mattd17
parimeter lighting is when the headlights turn on after unlocking the doors. i cant speak for all aftermarket, but i know that at least a few will lose that option.
Old May 20, 2008 | 05:05 PM
Buck 1's Avatar
Buck 1
I also have the Crimestopper unit, and have had no problems with it. Works from quite a distance, and never has failed. I had it installed at a local Ford dealer, and the total cost was about $300.
MiamiPSD
Feb 23, 2010 07:40 AM
chrowen
2004 - 2008 F150
Dec 13, 2009 05:29 PM
68 351 bronc
Aftermarket Products
19
Jan 21, 2008 11:05 AM
njf207
Dec 22, 2005 08:38 AM
ptong
Dec 9, 2002 09:50 AM
