carb flooding after shutdown!! help please
Old May 17, 2008 | 08:23 PM
51merc's Avatar
51merc
Hi All...
Been a while...been working on other projects....a little bit here and there on the ol merc.
She runs great, but when i shut off the motor, i can hear gas burbling in the carb and it is comes out of the gasket between the carb and intake. What the heck is with that? Any advice would be much appreciated.
Also, what is the idle RPM on a stock 239 flathead supposed to be?
Thanks in advance...
Rick
Old May 17, 2008 | 09:26 PM
51ford fan's Avatar
51ford fan
I would suspect a faulty Needle and Seat or float adjustment. Or fuel pressure to high if your running an electric fuel pump.
Old May 17, 2008 | 09:31 PM
Old F1's Avatar
Old F1
Hello Canuck neighbour, Sorry Rick, but it has been so long (good thing) since I worked on one of those I wouldn’t be any help. But I’ll give you my long distance wild a$$ cyber space guesses anyway.
If the float or needle and seat are allowing gas to leak past then it would try and fill up the manifold as long as the pump held some pressure. I defiantly don’t think it should leak out at the gasket because then when running it would suck air (vacuum leak), could it be leaking out the throttle shaft and not the gasket? If so carb is shot!
It is my understanding (probably wrong) that lead free gas as a much lower boiling or vaporizing point so maybe the percolating is just the gas boiling?
But I have been wrong before.
Old May 17, 2008 | 10:02 PM
fifty2f1's Avatar
fifty2f1
Sounds like your float is sticking or needs adjustment.
Old May 18, 2008 | 10:47 AM
petey shoes's Avatar
petey shoes
idle rpm 675-750, enough to keep oil pressure up yet not pull truck when braking. thats my personal opinion/decision. i set engine up for (feel). these guys are right, float is the culprit unless using electric fuel pump, then it,s all about pressure
Old May 18, 2008 | 02:35 PM
51merc's Avatar
51merc
yep..electric fuel pump
You guys mention float unless im using an electric fuel pump...which i am. Im using a 6 volt electric fuel pump, with a fuel regulator before the carb. (Actually running it through the mechanical, just removed the push rod to keep it stock appearing...).
Depending on how accurate the fuel pressure gauge is, im at approx. 3pds.
Im setting the float using the instructions that came with the rebuild kits. I have the chandler grove AA-1 carb..so am using the float level adjustment of 1-11/32" and the float drop adjustment at 1-7/16. At these settings, not much up or down movement in the float but it is at spec.
Any suggestions as to what the float should be at??
thanks again in advance..
Rick
Old May 18, 2008 | 04:24 PM
fifty2f1's Avatar
fifty2f1
I am not familiar with your carb but if it has the same bowl setup as the holley or stromberg then I always set the float with the top off and it is more than a little bit, maybe 1/2" or so, I never really measured it. I don't see that it matters whether or not you have a electric or mechanical pump. Your 3# sounds just a bit high but I don't know for sure, I run mine around 2 to 2 1/2#.
Old May 18, 2008 | 06:57 PM
e william's Avatar
e william
Hey Merc, I've read here that apx. 2lb. is good pressure for the stock style carbs. Also, my '54 still runs the 239 y-block and the book puts the idle at 400 rpm's...a little low for me. I have it closer to 600, still might back it down just a hair.
later, Ed
OldFordRacer
49
Jan 26, 2015 11:50 AM
adamkat22
Jul 14, 2013 01:10 AM
truckdog62563
May 15, 2009 06:00 AM
merc62
Mar 9, 2005 12:59 AM
merc460
Jun 14, 2002 09:42 PM
