I find that you have to move your eyes the least amount to see the bottom gauge. There for you should put the most looked at gauge in that position... I put the Pyro on the bottom.. boost in the middle and trans at the top.. The bottom gauge was the one that I didn't have to move my eyes off the road much to see !!! If I did it again I would get a four gauge pod and then I'd put the DP tunner switch in the pod itself !! I'm planning on moving my tranny gauge to another location and putting in the DP gauge switch in the pod !
Stick them in and hold it up an c where u like them better....after u get used 2 where they R it takes is a quick glance 2 C what u want . I don't think there is a best spot 4 any of them they r all easy 2 C
Joe-
Where's the front axle temp gauge?
What pressure is the air pressure gauge monitoring- air bag suspension?
Does Isspro make a type of guage you don't own?
What makes you guys say that? I don't see that it makes much difference unless you're getting distracted by the movement of the gauges.
Right after I installed my gauges, I kept running off the side of the road watching the needles move. You seem to punch it more to see the boost gauge jump, causing the fuel gauge to go down.
