ideas for mods
Old May 16, 2008 | 05:19 PM
dmncoon's Avatar
dmncoon
ideas for mods
hey there guys I'm new here and I was just wondering what type of mods I should do to my truck. I don't have very much money to spend and I was wondering what would be the most worth while. oh and hi my name is Logan.
early 99, 7.3l psd, no mods
Old May 16, 2008 | 05:24 PM
jwhitetail's Avatar
jwhitetail
Air intake and exhaust, gauges than a chip, should result in better mpg's
Old May 16, 2008 | 05:26 PM
jhand124's Avatar
jhand124
Welcome Logan, this is a great place to start
There are quite a few mods to do with little money, CCV, 6637, muffler delete, FPR shimming ect.
Build up that bank acct. and we will help you spend it.
Edit: reread your post. Best place to spend intake, exhaust or at least muffler delete, gauges, then a chip.
Old May 16, 2008 | 05:43 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Check this out
https://www.ford-trucks.com/forums/5...confusion.html
Old May 17, 2008 | 04:02 PM
dmncoon's Avatar
dmncoon
thanks
thanks allot guys. I've been reading about the 6637 mod. my question is how exactly does it replace your air filter. I have the stock air filter system with a K&N air filter inside it. I was just wondering whicch would be better
Old May 17, 2008 | 07:45 PM
PaysonPSD's Avatar
PaysonPSD
You better keep that K&N filter oiled well or the turbo will suck it dry allowing dirt to pass through and dust your turbo wheel. The first thing you should do is get rid of the K&N and do the 6637. Probaly cost less then one of those small stock replacement K&Ns. Trust me, this should be your FIRST mod.
Sorry, forgot my manners. WELCOME to FTE.
Old May 17, 2008 | 07:49 PM
megawatt00's Avatar
megawatt00
What Robin Said!!!!!
Welcome to FTE!!!
Old May 17, 2008 | 09:22 PM
UP_There's Avatar
UP_There
what everbody above said......and also consider changing over to synthetic oil, it's muuuuch better for the truck! And clean out that EBPS valve (exhaust back pressure sensor) that should help out your mpg's a bit. Welcome to FTE!
Old May 18, 2008 | 05:42 AM
RogueSpear2023's Avatar
RogueSpear2023
What everyone else said. muffler delete is pretty cheap and will give you a little more performance. Ditch the K&N before you have to replace turbos too. The 6637 is by far better than K&N. Other cheap mods CCV mod will reduce intake restriction.
Old May 18, 2008 | 06:46 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Don't think I would even take my truck to church today with a K & N air filter.
Old May 18, 2008 | 09:30 PM
dmncoon's Avatar
dmncoon
Alright thanks alot guys, where would i be able to purchase the 6637 and what all does it include?
Old May 18, 2008 | 09:39 PM
megawatt00's Avatar
megawatt00
You can get one at NAPA for around $40.00 or FleetFilter.com for, I think, around $26.00-$30.00 all it is is the filter.
UP_There's Avatar
UP_There
you can go to NAPA and get the 6637 for $45-50 bucks, or FleetFilter.com and look up the 46637 for $28.29 plus shipping, same filter. It only includes the filter itself, you'll probably wanna go with a small piece of 4" exhaust pipe, or PVC to attach it securely to your intake tube.
Old May 18, 2008 | 10:28 PM
white Buffalo's Avatar
white Buffalo
Here's a pic of what the 6637 filter looks like installed.
Old May 19, 2008 | 04:58 PM
dmncoon's Avatar
dmncoon
wow thanks guys. There are actually two nappa stores around the area i'm located in I know one of the guys I'll check with him
