Gauge Sequence
Old May 17, 2008 | 04:21 PM
Automator's Avatar
Automator
Gauge Sequence
Ordering Auto Meter A-Pillar gauges (triple) and trying to figure out what order to put them in. What position is the easiest to read? I was looking at putting the pyro in the easiest to read position, then the boost and finally the trans temp. I am looking at doing the gauge mount for the DP-Tuner that will come after that (5" exhaust at same time as gauges).
Old May 17, 2008 | 04:28 PM
superduty4x4's Avatar
superduty4x4
Just pick your poison and go with it. Me I'm going to do boost on bottom, trans temp, and pyro in that order (I think anyways )
Old May 17, 2008 | 04:37 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
The one that moves the most at the top, the second fastest moving in the center, and the slowest on the bottom...
Old May 17, 2008 | 04:43 PM
nhill2090's Avatar
nhill2090
I LIke the order pyro, boost, trans..even though mine arent in that order. Kris's order with most moving-least is a good idea too!
Old May 17, 2008 | 04:49 PM
rebelchevy02's Avatar
rebelchevy02
I like the pyro in the closest, or most obvious place, its the one i pay the most attention to. The rest are less frequently looked apon. Just my .02
Old May 17, 2008 | 05:23 PM
rivrrunner's Avatar
rivrrunner
if you need glasses to read you may find that the pyro is better on the bottom or second to the bottom, I had pyro at the top and it was kinda blurry to me...it all boils down to personal choice IMO..I have w/ a 4 pillar gauge set DP gauge (easy to reach) trans (doesn't move fast) pyro then boost.
Old May 17, 2008 | 05:24 PM
Automator's Avatar
Automator
I am going to do Top: Pyro, Center: Boost, Bottom: Trans Temp. Seems a logical order. If I do the DP-Tuner on the gauge, is it better left (outside) or right (intside) on the pod? Seems that the left side exposes it to damage more, but is easier to reach.
Old May 17, 2008 | 08:01 PM
orng1's Avatar
orng1
I'm my turbo import I have my boost gauge on top and the A/F on the bottom. The boost is so easy to read, I think in the 7.3 I'm going to go with the pyro on top as that is the most important. Probably should change my car around so that the A/F is on top as it's a lot easier to read there.
Old May 17, 2008 | 09:07 PM
UP_There's Avatar
UP_There
Mine is pyro on top, boosht in the middle.......tranny temps on the bottom, like Kris said......in order of the fastest moving ones is your best bet
Old May 18, 2008 | 10:52 AM
Automator's Avatar
Automator
Not having gauges yet, does the pyro change that much?
What kind of boost levels should I expect?
Old May 18, 2008 | 11:42 AM
UP_There's Avatar
UP_There
The Pyro is definitely the most active gauge by FAR. And for boost levels......depends if you have a Chip/Tuner or not. With a DP....you can get upwards of 30psi.....in stock form you will probably get to levels in the 18-20psi range unless towing. Keep in mind.....your turbo won't like seeing levels of 26psi and above for long periods....not a good thing.
Old May 18, 2008 | 11:54 AM
superduty4x4
What makes you guys say that? I don't see that it makes much difference unless you're getting distracted by the movement of the gauges.
Old May 18, 2008 | 12:00 PM
PowerstrokeJunkie
Your boosht moves shlower than the EGT?
Old May 18, 2008 | 12:04 PM
UP_There's Avatar
UP_There
I guess what I meant is the EGT is much more active then the boost.....it's all personal preference
Old May 18, 2008 | 02:13 PM
twags6's Avatar
twags6
I'm taller, so I put the pyro on top and boost in the middle since thats around eye level. The trans temp is on the bottom since it moves the least and isn't checked as often as the other two.
