needing info
Old May 17, 2008 | 01:59 PM
61ford4u's Avatar
61ford4u
needing info
Hey guys i need to find out if i can use the motor mounts out of a 72 ford F250 to mount my 78 400 out of a Lincoln into a 61 Ford unibody without too much trouble....Thanks????
Old May 17, 2008 | 05:34 PM
85e150's Avatar
85e150
If only there were dozens or hundreds on this site using this swap combo. Alas, there is only one. You.
Define "too much trouble". Mock up, tack weld up, proof up, adjust up, weld up, mount up, drive off....
Old May 18, 2008 | 08:11 PM
61ford4u's Avatar
61ford4u
Thanks
Hey thanks for the rereply ... As i was waiting for an answer i went ahead and started the swap and it wasn't too much trouble at all...Like you said tack it weld it and drive off...If only it was that fast ,I got the mounts all in while i got the engine out I'm going to paint the engine compartment. Thanks Again it was a breeze....
orangeconv
Jan 14, 2012 11:35 AM
61ford4u
May 30, 2008 07:30 PM
HiPressure
Mar 14, 2004 01:03 PM
ZRX61
Dec 26, 2002 07:27 PM
