Transfer Case
Old May 17, 2008 | 12:16 AM
Vinford's Avatar
Vinford
Transfer Case
1994 F-350 4x4
Has anyone rebuilt there transfer case?
Mine seems to be doing some slipping and/or clunking when Im stuck.
Its like theres a broken gear that only catches sometimes?
Old May 17, 2008 | 06:52 AM
Cuda_jim's Avatar
Cuda_jim
You might want to look into it ASAP before some expensive stuff tries to jump out of the case.
Old May 17, 2008 | 07:37 AM
c00nhunterjoe's Avatar
c00nhunterjoe
i typicly see more 4407's in the standard trucks. the 1356 is more along the lines of the pto'd trucks if i recall
Old May 18, 2008 | 11:08 PM
mklemin's Avatar
mklemin
i just got don rebuilding my transfer case today wasnt that big of a chore really just take your time and patience i will be posting the pics i took durring the process to maybe help some. my truck had the Borg Warner 1356 transfercase in it dont know if that means anything to you there is a number ont the back of your transfer case you will have to clean it off to read it but the first 4 nums will tell you wich it is. anymore questions just give me a shout and i will try and help out. good luck
Old May 19, 2008 | 09:12 AM
tjbeggs's Avatar
tjbeggs
Originally Posted by c00nhunterjoe
i typically see more 4407's in the standard trucks. the 1356 is more along the lines of the pto'd trucks if i recall
Joe I think the 4407's are used in 250's and the 1356 in 350's. I have two 1356's, one is pto one is not. any body want a PTO t-case??
Old May 19, 2008 | 09:44 AM
Neal 97 250's Avatar
Neal 97 250
How does the PTO work? Does it spin all the time or is there another lever to engage it? I think it would be good to have for when and if you needed it. Kinda like the gun thing. I would rather have it and not need it than need it and not have it. Anyways does it come out the front or rear? I would assume rear.
Old May 19, 2008 | 12:44 PM
tjbeggs's Avatar
tjbeggs
The PTO will spin any time the trans is in gear. If needing stationary PTO put the t-case in neutral. The PTO mount is on the right side of the t-case.
Old May 19, 2008 | 12:52 PM
MADVAN's Avatar
MADVAN
Tj
That PTO setup could come in handy when the bio system is up and running.
Would be a nice to be able to pump the dirty oil or transfer of the bio after.
Bill
Old May 19, 2008 | 01:10 PM
Neal 97 250
I am thinking Large air compressor...
Old May 19, 2008 | 05:24 PM
tjbeggs's Avatar
tjbeggs
I have racked my brain for a use for the PTO option in my truck but I just can't find a good use for it. To collect WVO I am using a super sucker using a 100 gallon propane tank that I will pull vacuum on with 1 of 2 pumps I have (12 or 110 volt). I did think about running a hydraulic pump off it then I could power what ever I want with hydraulic motors but to me its not really worth the effort.
Old May 19, 2008 | 10:07 PM
mklemin's Avatar
mklemin
Well my truck is a 250 and i had the 1356 t-case so i dont know there. i did have a truck that had a hydrolic wench that was one of the meanest wenches i had ever seen. pulled the truck up to a big tree front bumper first and pulled a smaller tree about 8" in diameter out of the ground. thats one option but who needs that.
Old May 20, 2008 | 06:43 AM
tjbeggs's Avatar
tjbeggs
Well that shoots that theory. Must depend on the day of the week the truck was built. LOL I don't know.
Old May 20, 2008 | 09:01 AM
BlueMule's Avatar
BlueMule
IIRC the year of the truck determines what transfer case it has and not F250 vs F350 or auto vs manual. 95 and earlier have 1356's and 96 and laters have 4407's.
4407's also have a flange on the rear output that the u-joint bolts to and the 1356's have a yoke that is splined to the output shaft.
Old May 20, 2008 | 10:04 AM
Vinford's Avatar
Vinford
Mine is the spline into the output shaft so I guess its a 1356.
Old May 20, 2008 | 10:07 AM
Vinford's Avatar
Vinford
I have a crane/picker on a old truck and its run with the PTO.
