Problems???? Wont start
Old May 16, 2008 | 10:19 PM
josegiron83's Avatar
josegiron83
Hello i am a knew guy here at the forum i apologyze if some one doesnt understand me (whit the english) becouse i am from guatemala but thats not the problem.
The really problem that i have i recently bought a ford f250 06 with 6.0 diesel engine its american. Last wensday i was driving and then sudenly the engine turned off and i cant find whats the problem the car have diesel have knew batteries have lights on the dash and when you turn the key to the 3 possition the starter works but the engine wont start like no spark in the gas ones...
one friend told me about the fuses that cuts the injection right down the passenger side yesterday i tried a dosnt work.
Someone have a CLUE????
Old May 16, 2008 | 10:27 PM
Industrial_dude's Avatar
Industrial_dude
does it have a kill switch? alarm system? yo no se maybe you ran outta fuel
Old May 16, 2008 | 10:35 PM
josegiron83
noup nothing have alarm but works whit gps system only you have to call to activate it
the kill switch i already cheked look normal fuel have one quarter???
Old May 16, 2008 | 10:44 PM
Industrial_dude
fuel pump?
Old May 16, 2008 | 11:22 PM
josegiron83
works??????????????????
Old May 17, 2008 | 12:40 AM
3000 FPS's Avatar
3000 FPS
If the engine is turning over good and does not start it has to be a fuel problem. There are many things that can prevent the fuel system from working such as the fuel pump or the fuel filter that is on the frame rail where the pump is. Then there is the IPR which is the injector pressure regulator and the ICP which is the injector control pressure sensor. These two items actually control the oil pressure going to the injectors to make them turn on and off. If either one of these is bad the truck will not start. I would also get a can bus reader and see if there are any diagnostic trouble codes that could point you to a possible cause of the truck not starting. There could be wiring that is chafed and also it could be the ficm relay or a blown fuse. Under the hood of the truck on the drivers side there is a black box with diagrams on top of it. Inside there is where the ficm relay is. FICM stands for fuel injection control module.
Old May 20, 2008 | 02:32 PM
josegiron83
Exclamation Help
I checked the switch of the passenger side its ok i scanned the computer and the computer said its ok everything What can be the problem?????
Old May 20, 2008 | 02:44 PM
josegiron83
Ive checked everything you said and the scanner turns to be ok!!! what can be the problem Help??
Old May 20, 2008 | 06:20 PM
lawnboy1965's Avatar
lawnboy1965
If you read some of the other forums they mention quit a lot the HPOP high pressure oil pump, and also a fitting. You might want to do a search for HPOP for more help.
oldbluebronco
1978 - 1996 Big Bronco
May 21, 2011 11:17 AM
blackout150
3.8 & 4.2L V6
Jun 30, 2009 11:55 PM
newford_owner
33
Dec 12, 2004 06:19 PM
IdahoCowboy
22
Aug 19, 2004 02:27 PM
