New Problem Today
Old May 16, 2008 | 05:31 PM
johnsjsj's Avatar
johnsjsj
New Problem Today
Driving The Truck Today. Everything Working Fine. Stopped At The Store And Locked Up The Truck. When I Came Out. The Electric Locks Would Not Work With The Remote. Opened It With The Key. On The Way Home No Problem. When I Got Home And Shut The Truck Off And Removed The Key, The Radio Would Not Shut Off; The Electric Door Locks Would Not Work From The Switch Or Remote, The Window On The Drivers Side Would Not Go Up Or Down With The Key On Or Off But The Passenger Side Window Would Go Up Or Down Even With The Key Off. Started The Truck Up And Shut It Down Several Times And Still Had The Same Problems. Need Some Help Please.
Anyone Had This Problem, Or Know What To Check?
Old May 16, 2008 | 05:55 PM
jhand124's Avatar
jhand124
Haven't seen that one yet, I'm interested to see the outcome though.
Old May 16, 2008 | 06:08 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I gotta guess your PCM has gotten wet. Has it been raining? Does your windshield maybe leak on the drivers side? These are really weird sounding problems. I too am very interested to hear what the real guru's come up with here.
Old May 16, 2008 | 06:15 PM
johnsjsj's Avatar
johnsjsj
No Rain, Sunny. Truck Has Been In The Garage For A Couple Of Weeks
Old May 16, 2008 | 06:23 PM
F350-6's Avatar
F350-6
Just to get it ruled out, go ahead and check your batteries and their connections, including the grounds. If your chasing electrical gremlins the first thing to rule out is the batteries.
Old May 16, 2008 | 09:29 PM
lee231's Avatar
lee231
Check all the grounds in the wiring system. If you lost a ground somewhere the current will try to find another way to get back to the batteries, what ever route that may take. There are ground points all over your truck, under the hood, under the dash, on the box, firewall to name a few. HTH and good luck. Lee
Old May 16, 2008 | 09:32 PM
megawatt00's Avatar
megawatt00
I agree with Chris and Lee it sounds like a grounding problem to me. I would remove and clean all ground connections.
Old May 16, 2008 | 11:59 PM
hucka1a's Avatar
hucka1a
I second checking the batteries and grounds. I have seen batteries cause the door locks and the radio go crazy.
Old May 17, 2008 | 12:38 AM
twags6's Avatar
twags6
Could this be the GEM thingy? I cant remember the correct name, but haven't there been a few guys that have 02's that had problems with them? They control all sorts of things like keyless entry, the drivers window (auto-down), dome light, etc..
Old May 17, 2008 | 04:12 AM
808 7.3's Avatar
808 7.3
sure sounds like a gem problem its mounted on the back of the fuse box check for corosion this is a programmable module and can't just be replace i did have this problem
Old May 17, 2008 | 05:24 AM
zx250's Avatar
zx250
Of the next Riffraff East
This really smells of an ECM (Generic Electronic Module) problem. It is the only thing I know of that controls all the devices you listed. You may can reset it by A: unplugging it, a real PITA, or B: unhooking both batteries, turning on headlights to drain every bit of juice to make sure the ECM resets. If not, might be time to replace the ECM. Of couse, do as the others stated, and check the batteries and cable. Weak current can make these things do some wierd stuff.
Old May 17, 2008 | 10:46 AM
AustinS's Avatar
AustinS
Sounds like a GEM module to me too. The '02's had some issues that reared up as the door problems.
Austin
Old May 17, 2008 | 11:08 AM
johnsjsj's Avatar
johnsjsj
Evil Ghost Attack
Went Out This Morning To Start Checking Things Out. When I Checked Everything One More Time; And Guess What; Everything Was Working Normal. Went Ahead And Wiggled All The Connectios I Could And Tightened All The Grounds I Could Find And Everything Still Ok. Guess I Will Wait And See If It Rears Its Ugly Head Again.
Thanks For The Sggestions
Old May 17, 2008 | 11:18 AM
SpringerPop's Avatar
SpringerPop
What have ambient temperatures been running locally there?
Pop
Old May 17, 2008 | 11:23 AM
Markadeck's Avatar
Markadeck
My radio has done whatever it feels like doing for years. Mostly in cold weather. It will turn itself on, switch to CD whenever it feels like it. I've just given up on trying to figure it out. It works just fine 99 and 9/10th's of the time. But I gotta admit it bugs me.
