2005 torqueshift rev. clutch replacement
My reverse clutch has slipped for a few months. I pulled the oil pan and found a broken retaining clip and few broken cast fragments. I reviewed the manual for the transmission and believe a can get to the reverse clutch at home. Other than visually damaged parts what else should i replace while i have the beast opened up. Also what special tools are required for the partial breakdown that are critical.
I don't know of anything to replace other than what's broken. I don't keep up with the aftermarket, so if there are better parts out there I don't know about them.
There was a problem with the reverse clutch snap ring in 2005. They made a change that didn't work out very well. I think you need to change the reverse clutch drum to get a better snap ring groove.
